01 civic k20a swapped
rsxguy
Re: 01 civic k20a swapped
Post by rsxguy »
ok finally figured out how to wire an 02 sensor in only problem is it only works for about 2 mins and then it loses comminication i had to wire in a relay for the heater circut
rsxguy
Post by rsxguy »
ok now that i can datalog can u guys see the studder around 1-2k rpms and does this tune seem ok
CalibratEd
Post by CalibratEd »
rsxguy wrote: Sat Aug 24, 2024 5:37 pm idk if u cau see whats going on just from this im holding it at 1500rpm and this is the studder does it while im driving too
According to the log, you are running very rich. If the wideband has been wired properly its reading 10AFR. That may be why the car is running rough. On another note, the car should be at 0 VTC at idle. Your tune has it commanding 20 VTC at idle. You're also throwing DTC code P0452 Fuel tank pressure sensor low voltage.
- Ed
Instagram: calibrated.tuning
rsxguy
Post by rsxguy »
how do i change that command in kpro? also i disabled that dtc
rsxguy
Post by rsxguy »
i think this is better?
