CalibratEd wrote: Wed Nov 15, 2023 10:11 pm
The car is running rich. The MAF table needs to be adjusted. Ideally when you change the intake you should switch it to run on speed density.
-Ed
Thank you for your help!! Running off speed density is using the MAP sensor instead of the MAF correct? Sorry I’m a noob when it comes to this stuff.
Yes that is correct. You would be running on the MAP sensor and not the MAF. You would then have to dial in all the fuel tables.
-Ed
Hey!
I don’t wanna mess around too much with the tuning, but I do want to fix my issue. Looking at the fuel low table it seems there are a lot of inconsistencies. Should I be attempting to smooth out the graph while still keeping the same shape of the line? Or should I just trim 5% from the overall fuel.
CalibratEd wrote: Fri Nov 17, 2023 5:45 am
Post the updated calibration file and a datalog. I can look over it and better assist you.
-Ed
datalog0005.fpdl
Factory Setting MAP Tune.fpcal
After changing it to speed density my car definitlely runs different. On startup it seems like the engine wants to cut out a little bit, but then after a few seconds it runs normally. Engine braking seems a lot smoother though. Thank you again for your help, I really appreciate it.
-Daniel
-Ed
I should add that when I started the car warm after going to the store, it started right up but then stalled out on me after a few seconds. Not sure if it’s a cranking fuel trim problem or what. I started it up again and gave it a bit of gas then it normalized, but without giving it some gas it’ll stall.
CalibratEd wrote: Sun Nov 19, 2023 3:57 pm
Fueling looks better. Create another log.
-Ed
datalog0009.fpdl
When the car would slow down to around 20kmh in neutral, a couple times it wanted to stall then it would rev up to around 1400 on its own to keep it from stalling. Not too sure what would cause this.
