Page 2 of 2
Re: Acuity intake basemap
Posted: Thu Jul 06, 2023 6:00 pm
by CalibratEd
Rev hang was not turned off on the calibration. I went ahead and turned it off for you and made a few fuel adjustments.
-Ed
Posted: Fri Jul 07, 2023 12:43 pm
by Gunish
Everything feels so much better. I posted city and highway datalogs after the last map. If you could just confirm if it's still running lean or not.
Posted: Fri Jul 07, 2023 1:40 pm
by CalibratEd
Still running lean at part throttle. In WOT it is fine. I made bigger adjustments to the fuel in part throttle.
Load the file and create a new datalog.
-Ed
Posted: Sat Jul 08, 2023 3:51 am
by Gunish
I'm not sure if it's normal, but when I drop it to neutral, the rpms jump up slightly and then drop down around 900-1200.
Posted: Sun Jul 09, 2023 1:24 pm
by CalibratEd
It could be the fueling. I am dialing in the fuel at part throttle.
Load the new file and create a new log.
-Ed
Posted: Sun Jul 09, 2023 8:15 pm
by Gunish
Feels better but I feel like at around 3-5k rpms there's a drop in power or something
Posted: Sun Jul 09, 2023 8:34 pm
by CalibratEd
This should be good enough to drive around until you get a proper tune. I reduced timing where i saw knock. You might have felt a lack in power if you hit a certain cell in the vtc tables they are not properly optimized. The car will run a lot better once you get a proper tune as all tables will be properly tuned. I made broad adjustments here to make sure the car is running safe.
-Ed
Posted: Sun Jul 09, 2023 8:37 pm
by Gunish
Alright, do you need me to post another data log, or should that do it?
Posted: Sun Jul 09, 2023 8:43 pm
by CalibratEd
That’s it. Reach it if you every need a full Etune.
-Ed
Posted: Sun Jul 09, 2023 8:44 pm
by Gunish
What difference would the fuel etune make?
Posted: Sun Jul 09, 2023 8:45 pm
by Gunish
Sorry, read that wrong. I'll send you a pm
Posted: Mon Jul 10, 2023 10:32 am
by Gunish
I made a lot of changes to the map myself. I'm unsure If I made it worse in any way, so if you could check it. I posted a datalog with it as well
