Injectors cut on shift - High revs
wal
Re: Injectors cut on shift - High revs
Post by wal »
I forgot to attach another example using full throttle shift
typer86
Post by typer86 »
Hi Wal,
yes you must deal in: Throttle flow vs. opening
https://k-tuned.3dcartstores.com/72mm-D ... p_878.html
(direct k-tuned TB guideline download-https://drive.google.com/file/d/141lSSu ... view?pli=1)
To avoid injector shutoff during shifting events increase the value:
Overrun Fuel Cut Delay
... in some start calibrations its configured to "0" ... In my case I have increased the value to 100ms to 120ms. To much time can cause long-term issues so its up to you to find the best value.
Also your "Overrun cut MAP (RECOVER)" value is also to high. The best smoothness tip-in you will have if you set a low value: 0,100 MAP (bar). Result: The injectors kick in faster.
Hope it helps.
BR
Jerome LP-Tuned Germany
