Page 2 of 2
Re: k24a FBO
Posted: Sat Apr 22, 2023 9:34 am
by CalibratEd
Mr_teller wrote: Sat Apr 22, 2023 9:28 am
I think the issue with mine is that it is stuck open. If I cover the opening in the throttle body I can hear the rpm’s come down. When disabling in kpro there is no difference. It is a brand new iacv so there is nothing to clean. I believe it is just faulty.
Did you remove the IACV and then disable it in Hondata?
Disabling it in Hondata will not make a difference if the IACV is still attached.
-Ed
Re: k24a FBO
Posted: Sat Apr 22, 2023 11:26 am
by Mr_teller
So Im sure its my IACV, i just took it apart and did some testing. I was able to block off the ports on my throttle body, but start up was rough and I cannot adjust my throttle cable any more to open up the throttle and do not want to adjust the screws on the throttle body. Looks like ill just order another IACV.
Re: k24a FBO
Posted: Sat Apr 22, 2023 11:33 am
by CalibratEd
Sounds good.
-Ed
Re: k24a FBO
Posted: Wed Apr 26, 2023 2:45 pm
by Mr_teller
Got the new IACV installed, Car is idling amazing now right around 900rpm. Made it around the block, came back and made some adjustments. Not sure when to pay attention to the knock count.
Re: k24a FBO
Posted: Thu Apr 27, 2023 6:10 pm
by CalibratEd
Make sure you post the file you made changes to. If you have severely reduced the timing in the knock area and the knock has not gone away it is more than likely false knock. You will have to do this to all the areas you see knock. I am glad the car is running better.
-Ed
