Page 2 of 2
Re: Flashing red light
Posted: Tue Feb 14, 2023 4:56 pm
Does the software show that it uploads?
Do you have on-board datalogging enabled in the calibration?
Post pictures showing the soldering that was done on the ECU for the s300. Include a picture of the top of the ECU circuit board too.
Posted: Wed Feb 15, 2023 6:14 am
by Shneaky
When I try to upload it would blink once red, stay solid red for about a second, then start and stay flashing red.
Onboard datalogging is enabled as well
Right now the car is running like it doesn’t have the unit installed at all.
Posted: Wed Feb 15, 2023 10:28 am
It looks like there may be some bad solder joints on the 4 pin connector and the 2 14 pin connectors.
disable on-board datalogging. It does not need to be on do datalog in the software.
Posted: Wed Feb 15, 2023 2:45 pm
by Shneaky
So resolder the pins?
And onboard datalogging was disabled
Posted: Wed Feb 15, 2023 6:28 pm
That is a starting point. Also I can see the capacitors have not been replaced in the ECU and one appears to already be leaking.
https://www.hondata.com/products/access ... acitor-kit
Posted: Fri Mar 10, 2023 12:55 am
by thirteen_20
I have this issue as well. 91 civic. Built b18c1. P72.
J12 has been cut. J1 jumped. Solder joints look good. Capacitors are clean. No leaking.
Socketed myself.
Can't upload, doesn't show when ignition is turned on.
Info is attached.
Posted: Fri Mar 10, 2023 10:34 am
With the USB unplugged, turn the ignition to the on position and tell me what the lights on the s300 do.
