2015 civic si hondata tune
Re: 2015 civic si hondata tune
I’ve already filled up the tank with 92 so you want me to do a wot pull in 3rd from 2500 to 7500 correct? And go ahead and drive for around 20 minutes
Yeah if you have time. Then we can get going on it. I wasn't sure if you had put 92 in. Go ahead and take it out, then we can see how far we can get on it so you can start having fun.
So I ran it twice because it was only showing about 85% on the throttle even though I had it to the floor but it came out the same on the second run. is that normal?
Are these datalogs made with revision 1 or 2?
Some cars the pedal only show 80 or low 90%, but the throttle body is 100%
they should be revision 2. I uploaded it after you posted it
Gotcha. The adjustments I made didn't get it too much closer is all. We'll keep going and see how it gets. We will now move to the 15* cam angle with vtec at 4500. Take this one for the same type of datalog and driving style with the third gear pull.
I'll be away from my computer for a couple hours, so no rush.
It's definitely feeling better than it did before. here's this datalog.
Yeah it's looking pretty good. We will now move to the 30* cam angle with vtec at 5500. I will move vtec around to find an optimal vtec rpm and tune the fuel around that point for future. So take this one for the type of drive and datalog.
Sorry it took me so long, I got a little busy yesterday.
It's looking good. We will now do one on the 30* cam angle with vtec at 4000. Take this one for the same drive and datalog.
sorry it's taking me so long. I've got the log, I can tell a difference in power from before.
No problem, it's looking really good. We will now move to the 40* cam angle with vtec at 5500. For this one, you can make a short ten minute datalog if you'd like. The main thing we need is a clean third gear pull.
Here's the log for the latest tune.
Looks pretty good. Just one more quick 10 minute datalog with a clean third gear pull for this one. This will be the last cam angle locked on, in the next one we blend it out to see how it runs. This one is the 40* cam again but with vtec at 4000.
it does seem like it pulls harder with the vtec at 4k, i know 3rd tops out of the same speed but it feels like it gets there faster with the vtec there.
