iPhone can’t find Flashpro
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
Re: iPhone can’t find Flashpro
The support info you sent said it was working normally now, but only the phone won't pair via Bluetooth in the mobile app.
What is the version of the mobile app you are using?
Can you connect via Bluetooth using FlashPro Manager?
Captainslow
Post by Captainslow »
I sent the feddback before I started the car. Lets forget about the bluetooth for now. We need to take care of all the alerts I see now. As I mentioned, I need my car operational
Captainslow
After I uploaded the calibration everything went haywire
Go to the online menu in the software and then click on OBDII diagnostics and try clearing the errors from there. If any remain, you will just need to drive it until they go away on their own.
Captainslow
I don't see any errors, but I see 5 monitors incompleted
Captainslow
In what tab should be error be?
Please confirm your FlashPro serial number so we can match this thread to any support information.
For the Bluetooth you need a PIN of 0000 or 1234 for it to work. Try 0000 then 1234. And for some phones they require you to try and fail 3 times before the phone will attempt to pass the PIN to the FlashPro because, for some reason, the way Bluetooth works is that the PIN is for the FlashPro connecting to the phone even thought it is the phone connecting to the FlashPro. One it fails a few times the phone will try the correct way.
Captainslow
OK I'll try that. As for the alerts, how long do I have to wait till they clear?
If there are no errors, then you just need to drive it until they go away. It may take several driving cycles.
Hondata wrote: Wed Jan 26, 2022 3:15 pm Please confirm your FlashPro serial number so we can match this thread to any support information.
Captainslow
Here is the latest update.
I went ahead and upload the calibration one more time. Like the last time, I did not see any error while uploading. This time no alerts came up when I started the car. I went for a long drive and so far everything looks good. In addition, the Bluetooth is now working, WOOHOO!
When I was having issue I saw and error message saying the hardware was failing. Is it possible that the hardware is going bad and as a result I had the issues? By the way, is there a different calibration for CTR turbo and Flex fuel?
Captainslow
Hondata wrote: Wed Jan 26, 2022 7:23 pm
I previously provided the serial number, but here it is again
Serial = FP-ACRD-US-170284
There is only one calibration and you can enable flex fuel in the mods.
There is no problem.
Captainslow
I suppose was too good to be true.
The car has been parked since the last time I drove it and today when I went for a drive I got some alerts again. I did not have any issues until I downloaded the latest software and updated the firmware on the Flashpro device. The error codes I'm getting are below
P2183
U0100
U0115
P0714
Please advice
Did you upload today before driving it?
