Page 2 of 4
Re: Need help with basemap fbo fg2 while tuner is available
Posted: Mon Sep 20, 2021 7:06 am
by joshuaanzures2002
I am about to start the data logs then ill send them over to you!
For some reason i couldn't find your email in the calibrations tho
Posted: Mon Sep 20, 2021 7:45 am
by EFICU
I'm an idiot, I made your file quick for the idle test and didn't put it in there. Post the datalog in here and we'll look at it.
Posted: Mon Sep 20, 2021 8:03 am
C:\Users\joshu\OneDrive\Documents\josh datalog.fpdl
i think it should work new to this let me know if it does.
Posted: Mon Sep 20, 2021 8:12 am
Not sure if i did it right for some reason i cant attach the datalog here. Can you tell me how to correctly attach it?
I think by email would be easier to send
Posted: Mon Sep 20, 2021 8:16 am
Posted: Mon Sep 20, 2021 8:41 am
by EFICU
You got it. You are definitely up there in elevation aren't you?
Overall it looked pretty good for a start. I made a bunch of part throttle fuel adjustments and some WOT fueling adjustments as well. We had a couple knock in part throttle, so I touched up the ignition there for you. Not too bad for a start though, give this one a drive with the same datalog and driving style and we'll see how it looks. But you can have more fun with it now that I have made the adjustments. It might still take a couple revisions to get it dialed, but it will be plenty close to have some fun with now.
I also fixed you file, my email is in there now if you need to email something to me.
joshuaanzures2002.SD.Rev03.fpcal
Posted: Mon Sep 20, 2021 8:50 am
Alright sounds good ill go ahead and do it again and send it to you!
And yes lol im in el paso,texas
Posted: Mon Sep 20, 2021 9:43 am
https://1drv.ms/u/s!AkCPHO448RxdgQoeQp6 ... 0?e=n9IQbN
here it is. what would you prefer here or through email?
Posted: Mon Sep 20, 2021 10:07 am
by EFICU
Here is fine. Per forum rules everything needs to be done on here, but there are certain times uploads can be difficult so I make sure there is alternate ways to get files sent when needed.
That one looked really good. Only made a couple part throttle and WOT fuel adjustments, and one area of ignition for some knock. Other than that, it's coming together. We might be there on this next one, but we will see.
Same datalog and driving style in this next one.
joshuaanzures2002.SD.Rev04.fpcal
Posted: Mon Sep 20, 2021 10:16 am
alrighty about to do it and btw i use 91 gas is that helps but ill send data log when done!
Posted: Mon Sep 20, 2021 11:15 am
there you go! car is feeling better and better everytime!!
https://1drv.ms/u/s!AkCPHO448RxdgQsgltG ... G?e=pk0nrJ
Posted: Mon Sep 20, 2021 11:49 am
by EFICU
Looks good. The fueling is pretty much dead on, I made a couple .25% changes on the WOT fueling and that was it. We had a few knock still, so I made some changes there. At this point we're just looking to remove the knock, everything else looks good. And the knock aren't anything terrible, it's just a couple areas where we're getting a couple, not a bunch at one time. So nothing to worry about, just nit picking it at this point.
Take this one for a drive when you can, I know you're getting semi close to heading off to work.
joshuaanzures2002.SD.Rev05.fpcal
Posted: Mon Sep 20, 2021 11:52 am
Actually its barely 1 pm here so i still have some time ill go ahead and do this one and send it as soon as im done!
Posted: Mon Sep 20, 2021 12:46 pm
Posted: Mon Sep 20, 2021 12:54 pm
I need help lol i think i fucked up . I accidentally pressed upload then cancelled,then i uploaded to make sure tune is in car now it wont turn on.
