2013 SI Exhaust and CAI base map
Re: 2013 SI Exhaust and CAI base map
updated
Looks really good for the most part. Not sure what the idle issue was, almost like residual fuel or something from when you shut it off before. Your old tune was rich beyond rich standards.
Here is the next one for you. Same type of datalog and driving. You can make a couple pulls if you'd like now, but keep the datalogs at least 20 minutes and make at least one WOT pull in third gear from 2500-7600. Looks good though, I made a couple fuel changes, but nothing major. See how it goes on this one.
very pleased with this one. quick question. is rev hang gone. didnt really encounter it which is good. drove Super nice
Yes rev hang is gone. I get rid of it from the start, and clean up the pedal map as well to make it feel a little better.
Glad you're happy with it. Here is the next one. I cleaned up some fueling and a couple knock that showed up. This one should be really close.
yessir. number 3 coming right up
Looks really good, we're almost there. I made a couple WOT fuel changes, and some ignition changes for knock. Had just a little knock in one area, so I pulled some to remove the knock. On this drive, get your third hear WOT pull from 2500-7600, and also get in a fourth gear pull from 3000-7000. Over 7000 rpm in fourth get going going fast. Don't get to 100mph and try to be safe where you do it. I use the fourth gear pull to make one last check for knock. Might be the last one, glad you're happy with it!
Loving it
Looks really good. Made a couple one percent changes to the WOT fueling and removed some ignition for knock. Really just need a datalog with a third and fourth gear pull now, the part throttle fuel looks great. So no need for 20 minute datalogs unless you want, just grab a third gear and a fourth gear pull just like that last drive you did and I think we're there. Just checking that fourth gear pull for knock now.
fire!!! lol drives smooth asf
Okay, looked really good. Let's do one more, just a third gear and fourth gear pull is all we need again. I touched up a little fuel and that's it. This should be really solid. If we get no knock and fuel looks solid again, we're all good.
thanks so much my man
Looks really good. I went ahead and made small change to the air temp compensation for fuel. Give this one a drive and we'll see how it looks.No knock which is good, now just tweaking the fuel one more time. Just need a third gear and fourth gear pull again.
Looks good man, fueling looks good and there is no knock still. Keep making datalogs over the next week or so, if any knock show up let me know and post the datalog.
				2013CivicSiSedan
Is EFICU still active? Could you help me with remote tuning?
