Kpro using the AiM MXS Strada
onslack
Re: Kpro using the AiM MXS Strada
Post by onslack »
Update -
Popped to my mapper yesterday, tested the dash on his ecu with a kpro v4, dash works fine on his ecu so that rules out the dash being a issue.
Swapped my kpro board into his ecu and the can stream drops still, so we swapped back to his board and the can stream works fine and doesn't drop. let the car warm up for 20-30 mins and there were no drops at all
We both concluded that there must be a issue with my board, so I've contacted PerformanceTek to take it from there
Kdp
Post by Kdp »
If you are still having issues with can bus going in aim ECU were it's say kpro click on kpro rs232 up load go to k-pro change from canbus to the green wire 232tx on kpro to white wire 232rx on AIM. kpro 232 rs brown to AIM blue 232tx go multi plexer digital output make sure you click on both AIM upload your done hope that helps
