Page 2 of 2
Re: Kpro datalog offline
Posted: Thu Nov 05, 2020 10:13 am
If it only happens in your vehicle you will need to resolve the issue, it is either a wiring related issue or a problem with the ignition causing interference.
Posted: Thu Nov 05, 2020 11:09 am
by Genchi
Plug E pin9 what voltage should reach that pin?
Posted: Thu Nov 05, 2020 11:29 am
You will need to check the factory service manual for specifics like that.
Posted: Thu Nov 05, 2020 11:53 am
by Genchi
It is necessary to connect the ELD SENSOR in the converssion harness?
Posted: Thu Nov 05, 2020 12:38 pm
No
Posted: Mon Nov 09, 2020 9:52 am
by Genchi
i have a big hunch that it may have something to do with my laptop...but anyway... when id datalog, it wont last longer than 30 seconds before freezing... im scared it might cause something wrong with my ECU... everything else works besides recording a datalog.
oh BTW...it only freezes when im driving... it doesnt freeze while at idle...only when i give it gas...
They have told me that it was my old laptop and the version of kpro that was a fresh update not being compatible
Posted: Mon Nov 09, 2020 11:47 am
You need to try your ECU in a different vehicle and see if the problem follows the ECU or if it is only on your vehicle.
