Page 2 of 2
Re: s300 v3 not reading any sensors
Posted: Thu Jun 18, 2020 9:11 am
Post a picture showing the bottom of the ECU showing the soldering that has been done for the s300. Make sure it is high resolution and in focus.
Posted: Thu Jun 18, 2020 4:17 pm
by Slowef9
That’s about as good as I can get it
Posted: Thu Jun 18, 2020 4:25 pm
Some of the joints look like they may not have flowed very well, and the 4 pin connector one looks like it is not soldered completely, and I cannot see the last pin of the 4 pin connector, or the 4 pin connector is in the wrong position.
Posted: Thu Jun 18, 2020 7:53 pm
by Slowef9
Yea I noticed that after I sent the pic touched it up a bit
Posted: Fri Jun 19, 2020 11:09 am
It looks like there may be a problem with the through hole and it may not be making contact with where it is supposed to go on the board.
Posted: Sat Jun 20, 2020 5:58 pm
by Slowef9
ok i will attempt to check it later is there anything you would recommend
Posted: Mon Jun 22, 2020 10:17 am
I would recommend that you replace all the capacitors in the ECU.
https://www.hondata.com/products/access ... acitor-kit
Posted: Tue Jul 14, 2020 9:12 am
by hondamike55
just got my new s300 prepped ecu from burton racing dropped my s300 chip in and I get the same results as my other ecu still cant read any of my sensors or datalog the chip will take a calibration and the car runs and will rev passed 4K and no engine light is on. I got one solid green light and a red flashing light just lost at this point any assistance will be greatly appreciated
Posted: Tue Jul 14, 2020 9:25 am
by hondamike55
Posted: Tue Jul 14, 2020 9:30 am
Is J12 cut in this ECU?
Posted: Tue Jul 14, 2020 9:36 am
by hondamike55
Posted: Tue Jul 14, 2020 9:37 am
by hondamike55
Posted: Tue Jul 14, 2020 9:38 am
by hondamike55
One of my ecu’s has j1 connected and my new one has it cut don’t know which is right
Posted: Tue Jul 14, 2020 11:01 am
If J1 is cut, the s300 will not work in it.
Posted: Tue Jul 14, 2020 1:11 pm
by hondamike55
ok so I put jumper in j1 and bingo all my sensors are reading and im able to datalog now so now I can book some time for the dyno and tune this bad girl in thanks again for the help spunkster your the man cheers
