Problem Hondata Flashpro
Re: Problem Hondata Flashpro
I have it but it doesn't work
My apologies, but there are two problems here (s2000 and non s2000) and the non s2000 problem is fixed with a software release yesterday.
Bociak : that's an old version.
Everyone else, please send the feedback information.
Then the link to the latest version, which I downloaded yesterday, was from:Hondata wrote: Sun Mar 29, 2020 7:25 am My apologies, but there are two problems here (s2000 and non s2000) and the non s2000 problem is fixed with a software release yesterday.
https://www.hondata.com/software
Clear you browser cache and download again. The compile date should be Mar 28 not Mar 20.
Ok. I did as you say, I downloaded the version from 28/03/2020 and continue the same.Hondata wrote: Sun Mar 29, 2020 7:34 am Clear you browser cache and download again. The compile date should be Mar 28 not Mar 20.
Ok. Feedback was sent from " niedlacb.botku@gmail.com "
It was a pleasant surprise to wake up and see you had already responded, I do appreciate your attention and I'll give credit when it's due.Hondata wrote: Sun Mar 29, 2020 7:25 am My apologies, but there are two problems here (s2000 and non s2000) and the non s2000 problem is fixed with a software release yesterday.
I just sent feedback through FlashPro Manager. I couldn't figure out how to attach screenshots there so I'll post the ones I took here.
Well, now we have to wait for a positive solution to the problem :)
Bociak: your FlashPro is 3.5.4 but the last upload was from the older version 3.4.4. I can see that you've gone back and forward between three different versions so can you please remove all the installations apart from that dated Mar 28 build 1478.
Everyone: please don't install old versions or run any software older than the most recent version, which is currently build 1478. Older versions are not going to work no matter what you do and it just makes my job much more difficult.
I have the latest version from yesterday installed on my computer. I don't have any other version.Hondata wrote: Sun Mar 29, 2020 9:44 am Bociak: your FlashPro is 3.5.4 but the last upload was from the older version 3.4.4. I can see that you've gone back and forward between three different versions so can you please remove all the installations apart from that dated Mar 28 build 1478.
Yesterday from morning to night I was thinking what to do to toss the map. So I installed 3.4.4 and newer. This morning I installed the second computer from March 28, 2020 and unfortunately it is the same as yesterday.
The last upload was made with 3.4.4. Can you try with 3.5.4 and send the feedback again?
I am sending feedback from v3.5.4.0 - 28/03/2020 againHondata wrote: Sun Mar 29, 2020 11:22 am The last upload was made with 3.4.4. Can you try with 3.5.4 and send the feedback again?
Bociak: Still shows as 3.4.4. I have fixed the problem for the S2000 and will do a build and release shortly. I suggest you get that version (3.5.5) and we'll see if that shows the right version.
M3AMI: Doing a build now to fix your problem.
Thanks for your patience.
Hondata wrote: Sun Mar 29, 2020 11:51 am Bociak: Still shows as 3.4.4. I have fixed the problem for the S2000 and will do a build and release shortly. I suggest you get that version (3.5.5) and we'll see if that shows the right version.
OKAY. I am just installing a new operating system on the laptop. So I'll wait with installing ManagerFlashPro to version 3.5.5.
