Page 2 of 2
Re: Help - Car cuts off Check engine light but no Code? (log added)
Posted: Thu Jan 30, 2020 10:36 am
Try swapping in a stock map sensor after changing the settings for it and see if the issue is resolved. If it is then you have a bad map sensor.
Posted: Thu Jan 30, 2020 11:40 am
by jetspeedz
Thanks, that is my plan, i don't have a stock map sensor but will order a new 4 bar map sensor via amazon and test. If it's not the map sensor it has to be the wiring harness on that sensor.
Is there a way to zoom out to the whole datalog if setting new start and end time?
Posted: Thu Jan 30, 2020 11:52 am
Once you set a new start and end point the rest of the data is lost.
Posted: Thu Jan 30, 2020 1:17 pm
by jetspeedz
Got it thanks a lot.
Posted: Mon Mar 02, 2020 8:22 pm
by DA9LEO
I noticed in your boost control settings in your parameters, you have pwm activating at -10.1 inches of vaccum. maybe look into the duty cycle and how you have your pwm setup in that table also
Posted: Thu Apr 23, 2020 5:55 pm
by jetspeedz
It was a bad Map sensor, replaced it with a Omni 4 Bar and its driving perfectly normal again. The owner at Omni is awesome that is all I can say.
