leaning out during idle
AREA876
Re: leaning out during idle
Post by AREA876 »
If the fuel pressure is really 45psid then it should look like this
Efreng35
Post by Efreng35 »
Awesome I will try that out! I appreciate the help I will load this up and and data log
Efreng35
Post by Efreng35 »
Car will not idle with those deadtimes and witty current deadtimes begins to sputter when I lean out the idle
Efreng35
Post by Efreng35 »
datalogged idle with me flipping window switches and turning lights on goes much leaner
AREA876
Post by AREA876 »
The highest I see it went was 1.01, try increasing the voltage below 13.96 by 0.02 and see if that helps with the AF with load.
Efreng35
Post by Efreng35 »
Ok will do you think it’s deadtime related?
AREA876
Post by AREA876 »
I think that should help
Efreng35
Post by Efreng35 »
Ok I’ll adjust and log again. I’m not sure if it would help but I was thinking of running direct power to pump through relay
AREA876
Post by AREA876 »
That is a good thing to always do
Efreng35
Post by Efreng35 »
Okay I will do this after work and log the differences I appreciate your help.
Efreng35
Post by Efreng35 »
I ran my wideband to the eld connection. I’m wondering if not having eld connection in causing the issue? Can I run ek civic with p28 hondata s300 with eld off ?
AREA876
Post by AREA876 »
Did you rewire the fuel pump?
Did you increase the dead time below 13 volts?
If so what was the result?
ELD is one of the recommended inputs
Yes you can leave the ELD disconnected as it is not needed.
Efreng35
Post by Efreng35 »
yes hard wired fuel pump and raised number still does same thing.
Efreng35
Post by Efreng35 »
I performed an idle relearn to the ecu seems to have corrected the issue.
