Low/high load ect fuel comp
dluder
Re: Low/high load ect fuel comp
Post by dluder »
Sorry I was referring to the ecu. I got another ecu from Hamotorsports and it does the same thing. So it's definitely got to be the s300 board. I was wondering how I can get a replacement since mine is defective?
Post your calibration as well as datalogs showing the issues between the 2 ecus.
dluder
Post by dluder »
Ok I'll post my calibration and datalog in the morning. I can post the calibration we used for my tuners ecu and s300 but I didn't get a datalog. Nothing abnormal shows up on datalog when the car misses or cuts out. When we hooked up my tuners ecu/s300 we uploaded my calibration and it was really lean everywhere. But once we added fuel it ran good and didn't hesitate/miss.
dluder
Post by dluder »
Im having issues sharing as zip how else could i share?
dluder
Post by dluder »
here is calibration
What is the serial number that is on the s300?
dluder
Post by dluder »
Sorry I'll post all the info in the morning I'm at work. Thanks
dluder
Post by dluder »
Not sure witch one is serial number
44949 or IIIr16
dluder
Post by dluder »
H22a4
11.1
Skunk2 pro1 cams
70mmtb ported IM/head
Fic 525cc injectors
H,I,e
Hamotorsports s300 ready ecu
Open lop tune
Replaced all sensors , injectors, injector pigtails, conversion harness, sensor pigtails, IM, all grounds, distributor, coil, plugs, plug wires, battery, checked alternator, compression 225 all 4 cylinders, leak down 5% on COLD engine lol ive checked everything. Replaced axles clutch nothing helped
dluder
Post by dluder »
Ran good on crome but went to s300 and had lil hiccup at cruise but it's got real bad now.
Post back to back datalogs showing the differences you are describing.
dluder
Post by dluder »
My tuner has been out of town so I've been unable to get a datalog with his s300. However I took my ecu cover off and went for a drive and noticed the RED light is flashing. I've changed ecu and conversion harness and checked harness for continuity and it's good. I'm pretty certain the s300 is the issue
Do you have on-board datalogging enabled in the calibration?
dluder
Post by dluder »
No it's not enabled
Send an email to support<at>hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Include a link to this thread
