Page 2 of 2
Re: FP Manager version 3.1.6.0: P0128 shows up when the DTC is disabled
Posted: Mon Jun 24, 2019 9:32 pm
If there is no input used on ECT2 then is should not be disabled.
With the 14/15 Si this version should fix the problem.
Posted: Tue Jun 25, 2019 5:10 pm
by Kevvo21
Hondata wrote: Mon Jun 24, 2019 9:32 pm
EDIT: okay so i just realized, the update you sent me is the current one I have. So as of version 3.4.0, unticking 'coolant thermostat temp check enabled' (p0128) does not remove the P0128 CEL.
Okay so my tuner got back to me and said that he disabled the 2nd ect because my fans weren't kicking in until very late, and by disabling it, it kept the car a lot cooler. I disabled P0128 in the calibration and the CEL still came up after 2 cold starts. That being said, disabling the 'Coolant thermostat temp check' does not work.
I am downloading the version that you linked above and will report back if it fixes or doesn't fix the issue.
Posted: Tue Jun 25, 2019 5:44 pm
The link I sent is not the same as any other released version.
Posted: Tue Jun 25, 2019 5:47 pm
by Kevvo21
Hondata wrote: Tue Jun 25, 2019 5:44 pm
okay thanks, will give it a try
appreciate the support
Posted: Fri Jun 28, 2019 3:09 pm
by Kevvo21
Alright so I went through 4 cold start cycles and so far no CEL! The update that was provided above works for the 14/15 Si. So for whatever reasons you have your 2nd ECT sensor disabled & the P0128 code disabled, you need the update provided above to get rid of the CEL.
Thanks for the help!
Posted: Fri Jun 28, 2019 6:36 pm
Thank you for the feedback.
Posted: Mon Jul 15, 2019 1:23 pm
by JDMisland
HONDATA can you please reactivate the link as I'm currently facing the same problems as the OP. When I try to click on the link you have provided it says, "The page you requested cannot be found!"
Thank you for your cooperation and looking forward to your response.
Posted: Mon Jul 15, 2019 1:30 pm
Just use the current version as it has the changes from last month in it.
Posted: Tue Sep 10, 2019 2:21 am
by Mr Hammond
Any chance the TB1 platform can get the same fix/update? We have the exact same issue for the exact exact same reason.
