Page 2 of 6
Re: Running Hondata Mobile on your radio/navi
Posted: Mon Aug 20, 2018 11:00 am
The head unit runs Android. An iphone has nothing to do with this.
Posted: Tue Oct 30, 2018 2:33 pm
by tc3sean
Sorry to bump such an old thread :X But does this work for the accord also?
Posted: Tue Oct 30, 2018 4:31 pm
No, it does not.
Posted: Sat Jun 15, 2019 2:17 pm
by jeffmo1129
So I had a 2017 Si and this process worked out great... now I have a 2019 and there's no Menu button to hit to get to the settings once you're in developer mode. Anyone know what buttons to hit? Thanks!
Posted: Sun Jun 16, 2019 7:02 am
Read the first post. We've updated it for the 2019.
Posted: Sat Jul 27, 2019 9:22 am
by Hodz_26
Hello,
I installed the app in my 2017 Type R yesterday. Everything rooted fine, the app installed without any issues and connected to my flashpro. My issue that I’m having with the app is when I release the parking brake, I get a message saying it can’t be used while the vehicle is in motion. Did I make a mistake somewhere with the rooting/ app install (seemed pretty straight forward) or will the Honda safety feature not let anyone run this while the car is moving?
Thank you.
Posted: Sat Jul 27, 2019 7:19 pm
In the rooting process a whitelist is changed that disables that message. How did you root the radio?
Posted: Sun Jul 28, 2019 6:20 pm
by Hodz_26
Hondata wrote: Sat Jul 27, 2019 7:19 pm In the rooting process a whitelist is changed that disables that message. How did you root the radio?
I rooted it using HondaHack and following the instructions in the Hondata YouTube video. Everything rooted fine and then I just installed the mobile app with a USB flash drive. Should I just follow the rooting steps and root the radio again?
Posted: Mon Jul 29, 2019 6:52 am
You might have to disable the parking brake check using Honda Hack. I can check later today.
Posted: Mon Jul 29, 2019 2:08 pm
by Hodz_26
Hondata wrote: Mon Jul 29, 2019 6:52 am You might have to disable the parking brake check using Honda Hack. I can check later today.
Okay, thank you for that info. I appreciate the guidance
Posted: Mon Jul 29, 2019 3:43 pm
In Honda Hack there in an option to bypass the parking brake, which installs an android service. I can't remember needing to explicitly click on it, but try it.
Posted: Mon Jul 29, 2019 8:07 pm
by Hodz_26
Hondata wrote: Mon Jul 29, 2019 3:43 pm In Honda Hack there in an option to bypass the parking brake, which installs an android service. I can't remember needing to explicitly click on it, but try it.
Okay, I will give that a shot, thank you.
Posted: Sat Aug 03, 2019 8:18 pm
by Hodz_26
Problem solved! Just had to go into HondaHack settings and toggle it to “on”. Everything works perfectly now
Posted: Fri Sep 20, 2019 4:00 pm
by dsegel
Is there any way to remove the app and/or root after it's been installed?
Posted: Fri Sep 20, 2019 4:40 pm
You should be able to do a factory reset of the headunit.
