FlashProManager 2.7.9.0
Re: FlashProManager 2.7.9.0
Just the boost level. Throttle response is the same between modes but we have noticed that most of the time the wastegate is shut the delay is the turbo itself. A/C operation is unchanged.
NoleenELT
Post by NoleenELT »
I just tried out the new +9 psi setting with "econ" mode setting on my 1.5T manual.
I love the functionality, but it seems to be making about 3-4 psi less boost than previously in each respective mode. In other words, it is reaching about ~12psi in econ mode, and about ~20psi in normal mode.
I drove around for 20 minutes or so, and the knock control % had stabilized already. I restarted the car a few times also.
I then flashed back to an older +9 psi calibration, and it is making >23psi.
Can you send the support information to use (from the help menu) so we can see what vehicle you have?
When you 'flashed back to a previous calibration', did you also change the software version?
NoleenELT
Post by NoleenELT »
I'm sending the info now, including data logs.
I'm not sure if this answers your question, but here is what I did:
-Updated flashpro to latest firmware (2.8.0.0)
-Loaded "Econ" +9psi map on to Flashpro
-Flashed to car directly from Flashpro
-Tested and found the situation described above
-Plugged in Flashpro to my PC, did not change firmware
-Loaded old +9psi tune from May 21, 2017 to Flashpro
-High boost is back
typer86
Post by typer86 »
Again, please confirm.
can I update my FP (for FN2) to 2.8.0.0 without issues?
There are no known problems with 2.8.0.0 and the FN2.
typer86
Post by typer86 »
Thanks - so I will install and test tomorrow.
