Re: S2000 AC not Working
Posted: Wed Oct 12, 2016 1:08 am
First turn the key in the on position, turn the fans on max and wiggle the relay side to side to confirm that is the issue. If that's the issue, then proceed below. I would look for another relay or trigger to wire it up to, maybe the ignition relay.
A quote from this thread:
http://www.s2ki.com/s2000/topic/795972- ... check-for/
"Well... I tinkered on and off for a good hour or two with nothing but a sign that the fuses weren't getting any power. I had a crazy thought last night to install my old relay tap (tap only with no wire leading anywhere)
And it worked. I guess installing the relay tap had expanded the metal contact inside the plug, so it needed that extra thickness to make the electrical connection."
