Page 2 of 3
Re: all 4 coils fire at the same time
Posted: Tue May 03, 2016 1:39 pm
This is for troubleshooting to help see where the problem might be.
Posted: Tue May 03, 2016 10:50 pm
by Wolli
i have ordered a new distributor to be sure. will need a few days. this is really driving me nuts!
Posted: Thu May 05, 2016 8:53 am
by Wolli
okay, got a itr or gsr distributor today. i changed some things to make him fit, and tada, car runs with the stock ignition. but when i put the cpr back in, the firing order is wrong! but i do not have the big bang layout anymore.
Posted: Thu May 05, 2016 9:24 am
What do you mean by you had to modify it to make it fit? Did you de-pin anything when installing this?
Posted: Thu May 05, 2016 9:37 am
by Wolli
i just had to swap the plugs, the pin layout was the same. the only thing was the part that goes to the camshaft. this is larger at the acuras, but was easy to swap. and yes, i took care not to install it 180° reverse! the ignition cables on the cap are also exactly like mine were.
Posted: Thu May 05, 2016 10:49 am
There is no difference between an Acura and a Honda distributor key. They are all interchangeable. In fact they are all interchangeable from a D,H, F or B series engine.
Did you de-pin anything with the CPR harness when you installed it?
Posted: Thu May 05, 2016 11:08 am
by Wolli
no, there was no need to!!
Posted: Thu May 05, 2016 11:14 am
So not it does not fire all 4 cylinders at the same time but the firing order is wrong? The only thing you have changed is the distributor? What is the part number of this distributor? Did all 3 tabs line up to bolt the distributor on?
Posted: Thu May 05, 2016 11:26 am
by Wolli
yes sir. it is a td-86u distributor. the housing and cap is a bit larger, but the holes fit perfectly! and also the timing matched with the stock one.
Posted: Thu May 05, 2016 11:41 am
by Wolli
maybe this helps also.
the colours of the cables to the coils are:
#1 yellow
#2 blue
#3 brown
#4 white
on the cpr plug viewed from the cables and lock on top:
black, red, yellow/red, purple, space, yellow, blue, brown, white
green is under yellow/red
Posted: Thu May 05, 2016 12:01 pm
by Wolli
i made a video and watched it in slow motion. the firing order is right, but when i turn the crank by hand, #1 starts at the wrong time!!
Posted: Thu May 05, 2016 1:20 pm
Post the calibration you are using to try to start the car.
Posted: Thu May 05, 2016 3:51 pm
by Wolli
this is it
Posted: Thu May 05, 2016 4:35 pm
What direction are you turning the distributor by hand?
Posted: Fri May 06, 2016 12:01 am
by Wolli
i turn the pulley on the crankshaft counterclockwise!
