all 4 coils fire at the same time
Re: all 4 coils fire at the same time
This is for troubleshooting to help see where the problem might be.
Wolli
Post by Wolli »
i have ordered a new distributor to be sure. will need a few days. this is really driving me nuts!
Wolli
Post by Wolli »
okay, got a itr or gsr distributor today. i changed some things to make him fit, and tada, car runs with the stock ignition. but when i put the cpr back in, the firing order is wrong! but i do not have the big bang layout anymore.
What do you mean by you had to modify it to make it fit? Did you de-pin anything when installing this?
Wolli
Post by Wolli »
i just had to swap the plugs, the pin layout was the same. the only thing was the part that goes to the camshaft. this is larger at the acuras, but was easy to swap. and yes, i took care not to install it 180° reverse! the ignition cables on the cap are also exactly like mine were.
There is no difference between an Acura and a Honda distributor key. They are all interchangeable. In fact they are all interchangeable from a D,H, F or B series engine.
Did you de-pin anything with the CPR harness when you installed it?
Wolli
Post by Wolli »
no, there was no need to!!
So not it does not fire all 4 cylinders at the same time but the firing order is wrong? The only thing you have changed is the distributor? What is the part number of this distributor? Did all 3 tabs line up to bolt the distributor on?
Wolli
Post by Wolli »
yes sir. it is a td-86u distributor. the housing and cap is a bit larger, but the holes fit perfectly! and also the timing matched with the stock one.
Wolli
Post by Wolli »
maybe this helps also.
the colours of the cables to the coils are:
#1 yellow
#2 blue
#3 brown
#4 white
on the cpr plug viewed from the cables and lock on top:
black, red, yellow/red, purple, space, yellow, blue, brown, white
green is under yellow/red
Wolli
Post by Wolli »
i made a video and watched it in slow motion. the firing order is right, but when i turn the crank by hand, #1 starts at the wrong time!!
Post the calibration you are using to try to start the car.
Wolli
Post by Wolli »
this is it
What direction are you turning the distributor by hand?
Wolli
Post by Wolli »
i turn the pulley on the crankshaft counterclockwise!
