You`re real lucky the released a beta just for your wideband.
When i had problems with live tuning tables it took a while to get fixed.
Analogue Inputs read wrong and closed loop functions incorrectly
Re: Analogue Inputs read wrong and closed loop functions incorrectly
Havent tested it yet but I will. Very surprised also, but given the somewhat "inaccurate" statement made that you can use wideband inputs for closed loop, I feel that its only fair. I think maybe soon they will update the information to state either that you must use a supported wideband, or they will change it to allow any analogue input wideband to be used (I see no reason why this cannot be done).
We can only work with what we are given in this case.
Ok closed loop is now working correctly. Thank you for updating the software to suit.
Hi, Thanks for beta version.
Also I use Techedge 2j9.
Civic eg K20A2, PRA, KPro 4
Today, I have tried for the first time to setup my closed loop but i received some error:
1-1: P0132 O2 Sensor voltage high
65-2: P0141 Secondary O2 Circuit Heater Circuit Malfunction
Wideband controller is now connected directly to the ground battery and positive of stereo connector.
I choose lamba as unit in the analog input config.
Maybe I have to modify Option->Setings->Units?
It was previously connected to the + and - of the ECU but Kpro detected a voltage fluctuations of 0.5V (both engine on and off)
Changed the source, the oscillation disappeared.
Unfortunately, I had not tried the closed loop with previous connections.
It's a problem of configuration, wiring or damaged components (controller or lambda)??
If I disable the closed loop, the wideband (on analog input 0) returns values, and errors not appear (save_160222_openloop.kal)
doesnt sound like an issue with your ecu cal. it sounds like the output on the techedge is giving more than 5v. Check the output signal on the techedge with a multi meter. Is it 5V or more? Im guessing its 9v. If its over 5v check the internal jumper which is for the WB- signal. It should be bridged to the techedge earth.
Make sure when testing the output signal it is connected to the kpro input as well.
Also, you should always have your earths for sensors at the same earth plane as your ECU which is reading them, otherwise you may end up with voltage offsets.
