Re: Pin d10 not responding to PLX sm-AFR analog output
Posted: Sat May 23, 2015 3:35 am
Come on guys, you can do better than that! :)
Test with 1.5v battery did not help much. As I was getting voltage from wideband analog output anyway... Just made sure ELD input voltage is not changing in sManager sensor window and so isn't the O2 (d14) pin
According to your statement "If you don't get close to 1.5V then the ECU doesn't support the ELD input", euro P30 ECU doesn't support narrowband O2 either which is impossible and we all can agree to this.
d10 input is not working and d14 input is not working (as I already described it in post #1)
