Need a base tune for a B16A with a GT32 turbo
mjalaly
Re: Need a base tune for a B16A with a GT32 turbo
Post by mjalaly »
actaully would it work to just import the table form your last file?
hpmx18
Post by hpmx18 »
ctrl-j
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
mjalaly
Post by mjalaly »
so is this correct?
Inital Start up maps 4bar (07jul15).skl
hpmx18
Post by hpmx18 »
yes this is correct
LGMotoring
Lgmotoring.com
mjalaly
Post by mjalaly »
ok i will let you know how it works.
mjalaly
Post by mjalaly »
Map sensor was defintly not working right. I installed the hondata one and it worked fine.
Put it on the dyno and it created 0psi of boost. neither i or the shop knows what is going on here. maybe its in the program?? some type of tuning issue that is causing it not to build pressure right?? Everything mechanically seems good.
AREA876
Post by AREA876 »
Do you have a boost guage?
If the turbo is spinning where is the boost going?
Maybe you have a boost leak
hpmx18
Post by hpmx18 »
was the turbo new if you try antilag will it build boost if not you have a boost leak or turbo or waste gate malfunction
LGMotoring
Lgmotoring.com
