Page 2 of 2
Re: Rev raise problem
Posted: Wed May 06, 2015 4:12 pm
by pa1nt13aller
Btw for those experiencing bucking and jerking after replacing a throttle body I have a thread in v6p for its fix. You need the HDS software to do a throttle plate relearn. But the rev hang is the ECU. And I hate it....so much.
Posted: Thu May 07, 2015 7:11 am
Larger throttle bodies are not electrically compatible with your ECU. See
http://www.hondata.com/forum/viewtopic.php?f=29&t=18527
Posted: Thu May 07, 2015 3:33 pm
by DomGSR-T
As for me on my TL-S I have the rev raise problem and jerkiness on the stock TB and on the ZDX TB. I use the stock TB for the last 8 months and the driving is not fun at all for a daily car...
Posted: Thu May 07, 2015 4:11 pm
Then with the stock throttle body, provide a calibration and datalog with annotations and an exact description of the problem, and we'll look at it.
Posted: Thu May 07, 2015 4:36 pm
by DomGSR-T
DomGSR-T wrote:email sent with cal and log.
Thanks in advance
already sent my map and log to hondata support email address
Posted: Fri May 08, 2015 7:40 am
DomGSR-T wrote:already sent my map and log to hondata support email address
Ok, thank you. I will look at it.
Posted: Wed May 27, 2015 9:13 pm
by DomGSR-T
Found anything yet? Is it normal that the timing stays ''ON'' when the %TB hits 0% ?
Posted: Mon Jun 29, 2015 12:26 am
by sockr1
any update to this issue?
Posted: Thu Jul 16, 2015 9:27 pm
by DomGSR-T
Yes problem is solved! Thanks Hondata!
Posted: Fri Jul 17, 2015 9:29 am
Did you use a newer version, or did you make other changes to the calibration?
Posted: Fri Jul 17, 2015 10:01 pm
by DomGSR-T
I just use the new feature that you have added for us. The one that was available for the kseries guys since version 1.7.0. Fixed the problem 100%
