Rev raise problem
FlashPro questions & answers specific to the 2007-2008 Acura TL
pa1nt13aller
Re: Rev raise problem
Post by pa1nt13aller »
Btw for those experiencing bucking and jerking after replacing a throttle body I have a thread in v6p for its fix. You need the HDS software to do a throttle plate relearn. But the rev hang is the ECU. And I hate it....so much.
Larger throttle bodies are not electrically compatible with your ECU. See http://www.hondata.com/forum/viewtopic.php?f=29&t=18527
DomGSR-T
Post by DomGSR-T »
As for me on my TL-S I have the rev raise problem and jerkiness on the stock TB and on the ZDX TB. I use the stock TB for the last 8 months and the driving is not fun at all for a daily car...
Then with the stock throttle body, provide a calibration and datalog with annotations and an exact description of the problem, and we'll look at it.
DomGSR-T
Post by DomGSR-T »
DomGSR-T wrote:email sent with cal and log.
Thanks in advance
already sent my map and log to hondata support email address
DomGSR-T wrote:already sent my map and log to hondata support email address
Ok, thank you. I will look at it.
DomGSR-T
Post by DomGSR-T »
Found anything yet? Is it normal that the timing stays ''ON'' when the %TB hits 0% ?
sockr1
Post by sockr1 »
any update to this issue?
DomGSR-T
Post by DomGSR-T »
Yes problem is solved! Thanks Hondata!
Did you use a newer version, or did you make other changes to the calibration?
DomGSR-T
Post by DomGSR-T »
I just use the new feature that you have added for us. The one that was available for the kseries guys since version 1.7.0. Fixed the problem 100%
