Page 2 of 3
Re: Kpro4 wideband lambda
Posted: Sat Nov 21, 2015 3:27 pm
by maxouni
I have not found wiring for digital input of wideband. Can anyone help me to wire it up?
Posted: Mon Nov 23, 2015 12:28 pm
http://www.hondata.com/help/kmanager/di ... ub=digital
I know it says Kpro3 only, but it also applies to the K-Pro V4.
Posted: Wed Jan 18, 2017 6:17 pm
by bdtan
Hondata wrote:What is the bosch 4.2U ?
With the KPro4 you can connect a wideband lambda with analog or digital output to the KPro4, and the KPro4 will send the lambda to the ECU. The ECU can then run in closed loop from the narrowband (PRA calibrations) or factory wideband (PRB calibrations) or from the external wideband (both PRA and PRB calibrations).
eg For a Euro CTR with a PRA ECU and PRA (or PRB) calibration you can run in closed loop from the external wideband.
eg For a US S2000 with PRB ECU and PRA (or PRB) calibration you can run in closed loop from the external wideband.
In both cases the external wideband can be used for datalogging (as it could with the KPro3).
Also in both cases the factory o2 sensor can be removed completely.
We've tried to put the same features in both the PRA and PRB calibrations now, so there is not much difference between them in features, but since the PRB calibrations are designed to run from a wideband sensor rather than the narrowband like the PRA, closed loop operation was better in our testing using a PRB calibration.
Hi the KPro Instructions and documentation say that the S2000 (2004 model) must "only use PRA ECU Calibrations," but in your post you reference using PRB calibrations with the S2000 KPro.
I'm trying to use my KPro in closed loop with my GlowShift wideband's 0-5V analog input input into my KPro4's analog input.
I had the car dyno tuned by Jim at Motorvations in AL. He was great. The car runs awesome at full throttle, but since he sent me away driving on the Open loop setting, it's not adapting to ambient conditions and is usually running rich at low or part throttle. I'd like to get my car to run better at low and part throttle and to adapt to ambient conditions to be better on gas consumption.
SHould I use the target lambda feature with the wideband? I tried running my car in closed loop using the wideband analog input, but it doesn't run very well...way too rich.
Would using the PRB calibration be much better?
What do you recommend?
Thanks,
Posted: Thu Jan 19, 2017 10:27 am
What is the serial number on the K-Pro board inside the ECU?
Posted: Fri Jan 20, 2017 5:40 pm
by bdtan
Spunkster wrote:What is the serial number on the K-Pro board inside the ECU?
Instead of pulling my ecu, can I connect my Kmanager and use the "send information..." function from the Help menu to send in ECU and calibration details?
Thanks,
Posted: Mon Jan 23, 2017 6:01 pm
IT will be best for you to open the ECU to get the serial number as this will also allow you to see what color the board is.
Posted: Sat Jan 28, 2017 10:45 pm
by bdtan
Spunkster wrote:IT will be best for you to open the ECU to get the serial number as this will also allow you to see what color the board is.
Here's a pic of my board.
I actually changed to an Innovate MTX-L last week, and it's still doing some wacky stuff when I try to run in wideband closed loop. It just runs way too rich even though I have target lambda tables set.
Posted: Mon Jan 30, 2017 10:23 am
There really is no preferred method, it is whichever is easier or you prefer.
Posted: Wed Feb 01, 2017 5:58 pm
by bdtan
Spunkster wrote:There really is no preferred method, it is whichever is easier or you prefer.
Okay, so I have a dyno tune already on a PRA calibration. How do I convert that to a PRB?
Also, do you have recommendations on the settings for running the car in wideband closed loop? I'd like it to run in closed loop all the time if possible.
If running on wideband closed loop is more problematic, do you see good results with narrowband closed loop on a setup like this?
Thanks,
Posted: Thu Feb 02, 2017 1:30 pm
You cannot easily convert a PRA calibration to a PRB. You can copy the ignition tables over, but the fuel values will be different and require retuning.
You can run closed loop form an aftermarket wideband with a K-Pro 4 and a PRA calibration.
Posted: Thu Feb 02, 2017 7:03 pm
by bdtan
Spunkster wrote:You cannot easily convert a PRA calibration to a PRB. You can copy the ignition tables over, but the fuel values will be different and require retuning.
Okay, but mine doesn't run well at all when using the wideband input. The computer doesn't come anywhere close to the target lambda, nor does it come anywhere close to the afcmd. It's all over the ultra rich and ultra lean. WOT is thankfully ultra rich instead of lean. But open loop seems to be tuned pretty well. Definitely at WOT, the afr is nice and flat as tuned on the dyno in open loop.
What might be causing this closed loop not being able properly get to target lambda?
Also, can I run in closed loop all the way through the rpm range and load range? up to 160mB?
Thanks,
Posted: Fri Feb 03, 2017 10:21 am
Has this been properly tuned on the dyno for all the load ranges you are trying to un in closed loop, or are you just expecting the closed loop to fully adjust to the running conditions?
Posted: Fri Feb 03, 2017 1:36 pm
by bdtan
Spunkster wrote:Has this been properly tuned on the dyno for all the load ranges you are trying to un in closed loop, or are you just expecting the closed loop to fully adjust to the running conditions?
This was tuned on a DynoJet for all load values as far I understand. Jim tuned for part throttle and idle. Of course it was tuned in open loop.
Posted: Fri Feb 03, 2017 3:11 pm
You should discuss this with your tuner as it sounds like some additional tuning may be needed for closed loop operation.
Posted: Tue May 16, 2017 3:21 pm
by Samrsx
Hondata wrote: Wed Dec 10, 2014 1:59 pm A wideband has two parts - the o2 sensor and the wideband controller. They must be matched to work.
The PRB ECU has the wideband controller inside, and will only work with the Honda o2 sensor.
If I understand correctly, the factory Honda o2, calibrated as a narrowband sensor, will work as a wideband just by using the PRB calbration in the ECU?
I know that the difference between narrowband and wideband is the calibration, but I do not know if the sensor itself is calibrated or it's only the ECU that applies the calibration.
Specific application: 03 Acura RSX (k20A3) with PRB ECU and PRB engine harness for k24 swap, so the o2 sensor is from a k20A3 base model (Compatibility)
