AN1(D12 pin) input ethanol content anylizer
aceman187443
Re: AN1(D12 pin) input ethanol content anylizer
Oh and the analog output of the Zeitronix eca display is linear and proportional to the output of the flex fuel sensors signal. Only difference is it has been internally "pulled up" inside the eca to 0-5v. I believe the the correct hookup if you have the eca display and still want to use it, and using the white board s300 is: on AN0 of the s300 plug on harness /TO/ eca analog output (0-5v blue/white wire). As for getting to try the remaining d10 channel to read i need to know, Do I need to order some diodes or just desolder and leave the pin holes empty? If you look in the help s300 area you will see it says , remove r2 and r3 or replace with 1n4048diodes
