Page 2 of 3
Re: CPR break up wont rev, no 2 step help
Posted: Tue Apr 29, 2014 11:19 am
The rev limit you are hitting in the data log is because of your launch control settings. If you are moving in any of these logs, the problem is that your VSS is not working.
Posted: Tue Apr 29, 2014 7:48 pm
by Gsrmike
All of these
Logs are stationary. They are NOT of my driving. Vss should reflect 0 mph on all logs Vss logs fine in my s300 and my cluster. It's simply
Me in my garage trying to hit 2step. The logs are not of me hitting launch control feature is set to 6300. as you can see with the logs it never reaches that (reference calibration for lanch control setting)
I redid all my
Grounds with 8awg wire
The valve cover one and I also have one from my water pump to chasis
As I asked earlier does it matter my icm wire was going back into the harness? Just asking it would be nice to not have that other loose wire to power tach
Posted: Wed Apr 30, 2014 9:16 am
Where on the valve cover is the ground attached?
As long as the original ICM wire is disconnected from the ECU then it should be fine.
Posted: Wed Apr 30, 2014 10:05 am
by Gsrmike
Oem location however, redid all of them because they were really old and extremely fraid !
Haven't Gotton a chance to really test it since the grounds have been installed.
Is it possible this could all equate to shitty grounds?
Hoping to get it down the 1/4 this weekend. I will report back updates. Anything else I can try before then? Is it possible I over heated a coil pack?
Thanks for ideas
Posted: Wed Apr 30, 2014 11:12 am
Grounding to that location does nothing as the valve cover is rubber isolated. It must be under the acorn nut but on top of the grommet holder.
Posted: Wed Apr 30, 2014 11:55 am
by Gsrmike
Spunkster wrote:Grounding to that location does nothing as the valve cover is rubber isolated. It must be under the acorn nut but on top of the grommet holder.
Naturally , the ground was not attached at that location lol, could this equate to a bad ground is that possible likely?
Posted: Wed Apr 30, 2014 12:10 pm
So far 2 of the 3 factory ground are not connected correctly, and you haven't even mentioned the factory transmission ground that goes to the frame rail.
Posted: Wed Apr 30, 2014 1:11 pm
by Gsrmike
Now the transmission one was solid but like I said I replaced all and added one
You are referring to the thermo housing ground was in the wrong place?
Posted: Wed Apr 30, 2014 1:20 pm
correct
Posted: Wed Apr 30, 2014 4:39 pm
by Gsrmike
Ok got the grounds covered
2 4 gauge
1 8 gauge
Moved to thermo housing
Posted: Sun May 04, 2014 4:45 pm
by Gsrmike
Well still breaking up!
Any more ideas?
Still haven't tried ecu or new coils
Posted: Mon May 05, 2014 10:17 am
There is no need to put a ground on the water pump.
Try a different ECU as that is about all that is left to swap.
From your pictures it looks like you have other wires in your harness that are damaged and could be shorting out or corroding. One example is your fan thermo switch on the thermostat housing.
Posted: Fri Jun 13, 2014 7:59 pm
by Gsrmike
Still having the same problem, we trying a different dizzy and I have a rywire harness we will try to.
I am still using s300 v1 that doesn't matter does it?
I need to upgrade to v3
Posted: Sat Jun 14, 2014 7:10 am
The s300 does not make any difference. The ECU may do.
Is it a new aftermarket distributor or is it a Honda distributor? We see a lot of problems with old Honda distributors and new (or old) aftermarket distributors.
Posted: Sat Jun 14, 2014 8:33 pm
by Gsrmike
Already tried different ecu at track same problem.
Yes I am tracking only to use honda oem ecu only problem is that I cannot find any brand new dizzy seems honda may have discontinued them. I am on a used one now but I figure best bet to get one from h motors with some low miles, unless you have a better source for new or low milage dizzy?
It just boggles me that it's only at the track I encounter he this problem and always on 3rd or 4th run
Thanks again for the help
