Page 2 of 2
Re: D16Z6 supercharged running very rich
Posted: Mon Apr 07, 2014 10:50 am
by zone_nord
Ok so I need to connect the analog out from the gauge to the d10 on the ecu not a0 on s300 right?
Do I also need to connect the secondary analog out (narrow band simulated signal) from the gauge to d14?
thank you very much for all the help
Posted: Mon Apr 07, 2014 1:15 pm
YEs that is correct. You do not need to connect the narrow band output.
Posted: Tue Apr 08, 2014 1:30 am
by zone_nord
on the D connector the d10 pin has no wire going in it
is this normal?
Posted: Tue Apr 08, 2014 2:12 am
by zone_nord
I set up s300 manager to read lambda on a0 just to check and with a 0.2 voltage offset the numbers match those shown on the gauge so it's all good
currently running in open loop
should I still connect the analog out from the gauge to d10 if I currently have nothing going in that pin?
thanks again :)
Posted: Tue Apr 08, 2014 7:27 am
by zone_nord
ok I connected the output to d10, with 0.2 voltage offset the values seem to match
14.7 afr at idle in closed loop - wideband input - lambda target
car is running good
at cold start until the wideband heats up the car runs very very lean and almost stalls for 5-6 seconds, after the wideband comes online everything is normal
this is not happening if I run the car in open loop
any idea why this happens?
cheers
Posted: Tue Apr 08, 2014 9:45 am
Impossible to say without the caliration and a datalog showing the issue.
Posted: Tue Apr 08, 2014 10:25 am
by zone_nord
yeah, sorry. i'm just starting to learn, did a ton of googleing/reading :) 10 more tons required
went to the car now to record a cold start log and it started fine this time
here are the files anyway so you can take a look
thanks
Posted: Tue May 27, 2014 3:17 pm
by Monnoracing
Make sure your map sensor is getting its vacuum reference after the rotors. I see it all the time where it is hooked up on the throttle body.
Posted: Tue May 27, 2014 8:21 pm
by zone_nord
you are right, my map sensor is on the throttle body so it cannot see boost
i have to re locate it
