Page 2 of 2
Re: Hondata EBC
Posted: Fri Oct 04, 2013 10:13 am
Check continuity to ground at the output from B21 with boost control enabled and disabled.
Re: Hondata EBC
Posted: Fri Oct 04, 2013 2:35 pm
by 05typeR
Test results:
Boost disabled: 0 ohms
Boost enabled: .8-1.7 ohms
Here lies our problem.
Re: Hondata EBC
Posted: Fri Oct 04, 2013 2:56 pm
If this is the case then your ECU is damaged in some way. As when you have the boost control enabled there is no duty cycle shown so it is not commanding the ECU to do anything.
Re: Hondata EBC
Posted: Fri Oct 04, 2013 3:22 pm
by 05typeR
here is another log i did a few days ago on Low cam 20* at 10psi
duty is 15%
i guess you didnt see the duty because it was done at idle, but this is when i have the problem.
i found it holds the 10psi but wanted to try another pressure port.
low 20 10psi 1.kdl
Re: Hondata EBC
Posted: Fri Oct 04, 2013 4:09 pm
Ok, so the boost control is working to build boost, and you are experiencing no other problems with how it runs? Correct?
Re: Hondata EBC
Posted: Fri Oct 04, 2013 4:16 pm
by 05typeR
Spunkster wrote:Ok, so the boost control is working to build boost, and you are experiencing no other problems with how it runs? Correct?
the last datalog was taken when the pressure from the turbo was T by the turbo.
i only came across the problem when i used a port on the intake manifold for the ebc pressure port BUT at idle and its more recognized at cold start/high idle the ebc is allowing vacuum to pass opening the WG when the boost control is enabled.
this is my problem.
why is vacuum allowed to pass.
Re: Hondata EBC
Posted: Mon Oct 07, 2013 4:54 pm
by 05typeR
so no more on this?
i know you guys dont like persons down grading but this is the only thing coming to mind to try.
Re: Hondata EBC
Posted: Tue Oct 08, 2013 9:49 am
What solenoid are you using?
Re: Hondata EBC
Posted: Tue Oct 08, 2013 9:59 am
by 05typeR
Hondata Solenoid, I bought the combo from http://www.kseriesparts.com/browse/cr/? ... versal=yes
at this stage the solenoid is not the cause because the problem only occurs when the 'boost control' is activated weather the solenoid is connected or not, the ECU is activating the ground circuit which is opening the solenoid at idle when the motor has vacuum.
Re: Hondata EBC
Posted: Tue Oct 08, 2013 12:34 pm
Are you saying that you are getting a vacuum leak at idle through the solenoid?
Re: Hondata EBC
Posted: Tue Oct 08, 2013 1:17 pm
by 05typeR
Spunkster wrote:Are you saying that you are getting a vacuum leak at idle through the solenoid?
the way i see it, the solenoid is being open at idle, cruise or WOT when it shouldnt.
this is the problem. why is the ecu grounding this circuit at a time when it shouldnt be?
the Hondata/Mac EBC solenoids are normally closed, with this being held open by the ECU changes this.
Re: Hondata EBC
Posted: Tue Oct 08, 2013 3:29 pm
It seems that when the variable frequency was added it intruduced this bug into the software. going to the non-beta version will continue to work as it should. I have made our software guys aware of the issue.
Re: Hondata EBC
Posted: Tue Oct 08, 2013 4:04 pm
by 05typeR
Spunkster wrote:It seems that when the variable frequency was added it intruduced this bug into the software. going to the non-beta version will continue to work as it should. I have made our software guys aware of the issue.
Great, Thanks!!
Will be looking out for this.
