FlashPro works perfectly with our UKDM CL9's all you need is an acura TSX 07-08 ecu, part number 37820-RBB-A21.
and of course FlashPro itself, part number FP-TSX-US
depending on the year of your accord depends on if you need the can bus adapter harness. (only two wires)
pre facelift CL9's (03-06) dont support CAN BUS so you will need the adapter harness.
or you can make your own if you can source two pins that you need to put into the obd2 socket.
first remove the panel from under the steering wheel.
on the right you will see these plugs.
the plug you need to plug into or solder from is the grey plug with the white, red and brown wires in. each row in this plug is common so all the reds are linked all the whites are linked and so are the browns so if your soldering the wires on you dont need to worry which wires you pick.
behind those plugs you can pop the panel out of the dash so you can remove the plugs so you can pull the towards you, makes it easier.
if your soldering then..
first you want to remove the brown tape from around the red and white wires as far down as you can to give you enough room to get at the wires.
then just solder one wire to the red and one to the white. easy peasy. be sure to insulate the cable afterwards you dont want them shorting out. a good tip is stagger where you join the wires together ;)
i dont have any pictures as i didnt do it this way but its pretty easy to explain.
next step is a pain in the backside.
pop the obd2 socket out of its holder.
download this pdf and read this will help for this part.
http://www.hondata.com/downloads/04-06_ ... nstall.pdf
skip to page two and start from step 3.
step 4 is tricky.
once you have popped both retainers out of the sides of the obd2 plug first you need to take the the grey wire out from pin position 14 and move it to position 1.
then you need to take your pins you have got from another obd2 plug and solder them onto the ends of your red and white wires.
the white wire then needs to be inserted into position 6 and red to 14.
then push the retainers back in on the plug and put it all together :good:
i used hondatas adapter harness mine looks like this
the red and white wires push straight into the two spare holes in the furthest left grey plug that only has the brown wire in.
i used a spare plug though as you can see mine is the white plug in the grey connector block.
