Full throttlle shift
rev hard
Re: Full throttlle shift
Post by rev hard »
o ok..and how do you set it up? ''always on'' ? does that use the clutch then?
boosted k20
Post by boosted k20 »
rev hard wrote:o ok..and how do you set it up? ''always on'' ? does that use the clutch then?
No you should wire in a clutch switch and then feed the signal from the switch to one of the inputs at the ECU. If you dont do that then your FTS rpm will be your rev limit
