Page 2 of 4
Re: SManager 2.2.0 (beta)
Posted: Mon Dec 17, 2012 1:39 pm
Can you email us any more calibrations?
Edit: Ok folks, I think I have traced it down to the wideband lambda table. We'll do an update shortly.
Posted: Mon Dec 17, 2012 2:32 pm
by AREA876
Hondata wrote:
Does everyone download from the ECU or do you load the calibration from the laptop?
Does the car run for some period of time and then fail to start, or does it not want to start immediately after the upload?
Can anyone else upload a calibration here (preferable not downloaded from the ECU)?
What version S300 are you using?
What version were you updating from?
1) Calibration was upload from Laptop to ECU
2) Car started and drove the first day, following day started, uploaded same calibration while engine was running and engine stopped running and would not restart.
3) S300 V1
4) Updated from 2.1.5.0
Re: SManager 2.2.1 (beta)
Posted: Mon Dec 17, 2012 11:44 pm
by skullbasher
i also need you to further elaborate on the soft launch as well. i dont get it. can you explain it for dummies. i launch with a 3000 launch and 2800 activation to grip in first with turbo and street tires. will this help me eliminate all the spinnage, please explain thanks.
Posted: Tue Dec 18, 2012 5:20 pm
by AREA876
I'm still having problem. I notice that my Closed loop TPS (Both Low & High)table start and end with 8000 RPM, same goes for my Minimum TPS for tip in retard. I tried to correct them to 500 rpm and saved calibration, but when I reopen calibration they constantly revert back to 8000 rpm . Here are copies of my calibration one from version 2.1.5 the other from 2.2.1, hope this helps.
Posted: Tue Dec 18, 2012 5:46 pm
I can confirm this, we will look into it.
Re: SManager 2.2.2 (beta)
Posted: Fri Dec 21, 2012 1:54 am
by allm0t0rGSR
i have a problem on the Minimum TPS for tip in retard. I tried to correct them to 500 rpm and saved calibration, but when I reopen calibration they constantly revert back to 8000 rpm
Posted: Fri Dec 21, 2012 8:00 am
This has been fixed with V2.2.2
Posted: Fri Dec 21, 2012 1:05 pm
by AREA876
AREA876 wrote:I'm still having problem. I notice that my Closed loop TPS (Both Low & High)table start and end with 8000 RPM, same goes for my Minimum TPS for tip in retard. I tried to correct them to 500 rpm and saved calibration, but when I reopen calibration they constantly revert back to 8000 rpm .
I tried 2.2.2, the problem with the Close loop TPS seems to be fixed but the problem with the Minimum TPS for tip in retard is still there. It starts at 8000rpm and ends at 8000rpm once you save and reopen the calibration.
Posted: Fri Dec 21, 2012 2:17 pm
Ok, thanks.
Re: SManager 2.2.3 (beta)
Posted: Sun Dec 23, 2012 1:26 am
by allm0t0rGSR
under the closed loop condition the maximum engine speed can only go upto 5000rpm, i change to 7500rpm but it keep goen back to 5000rpm... thanks
Posted: Sat Dec 29, 2012 11:21 am
by blackek4
allm0t0rGSR wrote:under the closed loop condition the maximum engine speed can only go upto 5000rpm, i change to 7500rpm but it keep goen back to 5000rpm... thanks
same problem here.
and I also can't change:
under closed loop:
- Closed Loop Max TPS (Low) & (High) - I tryed to set max rpm to more than 8000 and it doesn't let me.
- Closed Loop Max TPS (Low) & (High) - I set 100% to TPS %, but only assumes 99%.
And just a doubt regarding tip-in retard conditions, does both conditions need to be meet, for the retard occur, or just one of them? for example, if i'm in 2nd gear, at 5000rpm doing 50km/h, and i have set for the tip-in, vehicle speed min. 10 max. 140 and engine speed min. 1000 max. 4500, will the retard occur or not?
I'm already using beta 2.2.3.0.
Posted: Thu Jan 03, 2013 7:36 pm
by allm0t0rGSR
blackek4 wrote:allm0t0rGSR wrote:under the closed loop condition the maximum engine speed can only go upto 5000rpm, i change to 7500rpm but it keep goen back to 5000rpm... thanks
same problem here.
under closed loop:
I'm already using beta 2.2.3.0.[/quote
Anybody.....
Posted: Fri Jan 04, 2013 6:49 pm
by nayr_one
i cant get the test output function to work... do i just check the box?
Posted: Sun Jan 06, 2013 4:05 pm
by blackek4
hondata, any chance that we could get some input from you on the problems we found?
Posted: Sun Jan 06, 2013 10:01 pm
by justYncredible
i like this update features but im waiting until it gets out of beta phase to download. the last beta, screwed with my idle and afr but my tuner fixed it quickly and free of charge
just want to im super excited about the security feature, the more layers of security the better
