I think I have this figured out about the FANC override....
Re: I think I have this figured out about the FANC override.
ok, and do I use the nit/aux1 and set it up like that?
this is what the guy that posted the yellow diagram explained he did....I don;t understand the 2 wires on 85 with the diodes.....one goes to A12 and the other to the ECT sensor???
in s300 go to parameters click
Nitrous/Aux1
function.....scroll down to "generic output"
the area should be usable now
click the output tab which will give you "output contol"
scroll down A12 FANC (Radiator fan control)
the conditions,
then you can change what temp you want the fan to come on.
I use the water temp sensor on the side of the B-series head. the 12v side. with diodes to make sure the current is flowing the correct direction.
85 is the trigger that's why A12 and the water temp sensor12v side are going there
Nitrous/Aux1
the conditions,
