Page 2 of 2
Re: Engine light on cold engine
Posted: Fri Oct 05, 2012 1:05 am
by Nazul
I will try changing the sensor and check the connections or cables if they are damaged or making bad connection.
But how is it thats its making -27% fuel trim if O2 oxygen sensor is disabled on cold start?
I thought all lambda sensors we disabled when running on cold start?
Posted: Fri Oct 05, 2012 9:27 am
The PRA ECU does not use a wideband. It can only read a narrow band signal which cannot be used to acurately measure air fuel ratios.
Posted: Thu Oct 11, 2012 12:55 am
by Nazul
So this error can't have anything to do with the mapping right?
So i'm sure its a faulty oxygen sensor or wiring and nothing with the hondata?
Posted: Wed Oct 17, 2012 11:26 pm
by Nazul
How can i see in the logs that its making -28% fuel trim with faulty O2 sensor?
Posted: Thu Oct 18, 2012 9:37 am
Posted: Thu Oct 18, 2012 9:48 am
by Anjuna
I would purchase a LC-1 or wideband of sorts and wire it into the ECU.
Like spunkster said, the PRA ecu doesn't do wideband. With V3 you have plenty of analog inputs.
http://www.hondata.com/forum/viewtopic.php?t=12282
viewtopic.php?p=38721&highlight=lc1#38721
Posted: Fri Oct 19, 2012 3:26 am
by Nazul
Ok yesterday i checked the cables on ecu, nothing wrong, i pushed them firmly in to be sure.
Then i checked the cable to the oxygen sensor.
Apparently there was a extension cable to the oxygen sensor, I got this out and connected the oem cables firmly again.
No errors since then.
The car runs good now under 4000 rpm, even on cold start.
I still have to do a log to check fuel trims are between -10% and +10%
Also i have corrected my gas cable a bit do have quicker response touching the padle.
I hope this has no influence to the mapping? Fuel maps, or timings?
