FlashProManager V1.3.7 (beta)
Nike
Re: FlashProManager V1.3.4 (beta)
Post by Nike »
Hondata wrote:It is available for the Euro CTR - wait for the release tomorrow.
Where is it?
civicRSA
Post by civicRSA »
Where is it?
Download V1.3.4 again. It has been added.
Take note that only once you plug a traction control unit into your PC will the addition TC table become visible.
beaugus
Post by beaugus »
Hondata, is there any chance you could add the option to input custom gear ratio values for the 04-05 TSX in an upcoming beta release?
One of the outstanding issues with using an 07-08 TSX ECU's in my Australian delivered Accord Euro (and I'm sure this is applicable to anyone else using a TSX ECU with other international Accords as well) is getting their cruise control to work.
For comparison sake the difference in gear ratios between the TSX and Accord Euro are;
Accord CL9 Euro:
1 - 3.533
2- 1.880
3- 1.354
4 - 1.027
5 - 0.825
6 - 0.659
Final 4.388
Reverse 3.583
Acura TSX:
1 - 3.266
2 - 1.880
3 - 1.355
4 - 1.028
5 - 0.825
6 - 0.659
Final 4.760
Reverse 3.583
VitViper
Post by VitViper »
Hondata wrote:Should be there in the tables window under 'Water temperature ignition retard'.
The hidden table that has been screwing with EU FN2 tuners for quite some time now... funny how they couldn't figure it out. It was easy to fix even without direct access to this table.
Thinking outside the box 4tw.
ash_rage
Post by ash_rage »
ROFL :-D
Nike
Post by Nike »
To Hondata:
I have changed to the final drive. After that the cruse control is not working. May you will add function to the correct final drive?
P.S. Civic US R18 5MT 2006. Thanks.
martin.ring
Re: FlashProManager V1.3.7 (beta)
Post by martin.ring »
Hi, i have a stupid quastion, if i have the flashpro i still need to bye the boks for traction kontrol?
I assume you are asking if you have to purchase traction control separately... the answer is yes.
Nike
Post by Nike »
Nike wrote:To Hondata:
