Closed loop not working
Re: Closed loop not working
It just adjusts the short term fuel trim to get it close to whatever you have it set to in the settings. It does not do anything electrically.
B18glaw
Post by B18glaw »
Can I adjust the settings on the short and long term fuel trim or do I need another map made up because this current map was done in the fall so it was colder
HAve you taken this to your tuner or asked them about this?
B18glaw
Post by B18glaw »
I had this problem when I first got my car tuned and it wasn't working properly. They suggest I conract hondata for answers
B18glaw
Post by B18glaw »
what if i raised the short term fuel trim settings higher?
going to be calling during the week soo i can actually talk to some one
B18glaw
Post by B18glaw »
why post that link?
becasue you still have not posted what it says to post
B18glaw
Post by B18glaw »
We've been over everything and pretty much on the same page...do you work for hondata? Absolute worst service I've ever experienced...don't want a bad wrap of hondata going around do you?
You have not posted the calibration or told us everything that has been done to the vehicle.
B18glaw
Post by B18glaw »
calibration
b18c with 84.5mm pistons
gt37r
1000cc dynamic injectors
skunk2 pro1 cams
hondata 4bar map sensor
68mm tb
Can you also provide new datalogs showing the problem using the new version of software.
B18glaw
Post by B18glaw »
here i have proved 4 datalogs 20sec each... 2 at cold start and 2 at operating temp, both temps i logged open and closed
What AEM wideband are you using? Have you tried a different input as suggested previously?
You appear to have some electrical issue as your battery voltage is vastly different between datalogs.
B18glaw
Post by B18glaw »
Currently aem uego is connected and battery may have been slightly low when first started.
What kind of electrical issues would affect the input signal...a ground?
