DLC not working
Re: DLC not working
An 05 Si will also work.
ninetysixyenko
Re: DLC not working
Post by ninetysixyenko »
Spunkster wrote:An 05 Si will also work.
Can I ask what would this be testing? Eliminating the Jumper harness being bad? If it doesn't work on an older model, then the Kpro ECU is definitely bad?
Re: DLC not working
correct
ninetysixyenko
Re: DLC not working
Ok, i'll try to get my buddy up here to try it out tomorrow. I have a friend with an 05 RSX like mine, but im assuming that wouldn't work, because it wouldn't eliminate the harness being bad.
Would it work on an 02 automatic RSX, for the DLC purposes? i do know someone with an auto also.
ninetysixyenko
Re: DLC not working
2005 civic SI. 2 different tries. Did not work. Now what? Can I get it replaced?
Re: DLC not working
If the ECU is damaged you will have to supply a working ECU to transfer the K-Pro into.
ninetysixyenko
Re: DLC not working
Spunkster wrote:If the ECU is damaged you will have to supply a working ECU to transfer the K-Pro into.
How am I responsible for a new Ecu when I ordered a brand new Ecu from you.
