Re: Afm fuel table
Posted: Wed Jul 22, 2015 11:08 pm
What i mean is as follows:
If we use a Hybrid Cal (MAF cal with MAP fuel tables), select "Use speed/density (MAP) fuel tables" and put in "Minimum pressure for speed/density" for example "1 Bar" as pressure, then the ECU behaves under this pressure like a AFM Cal (mass flow) and over this pressure like a MAP Cal (speed/density).
Is it right and you understand now, what i mean?
Thanks!
Thanks!
