Page 2 of 2
Re: always hang when datalog
Posted: Tue Apr 24, 2012 8:05 pm
by dneil_27
Same like my problem last time, u should try to check all the ignition system. starting from spark plug, spark plug wire, dizzy cap or dizzy itself. Try to change one by one and see if it make any diffrent to ur datalog.
Posted: Wed Apr 25, 2012 3:41 am
by PACMAN.AU
Changed my plugs, works fine now.
The problem is, I slay had resistor tour plugs in!
I swapped plugs for exactly the same plugs I already had...
Though, I'm working on the theory that one of the leads wasn't pushed all the way onto the plug properly....?
Meh..... That explanation will do me....!!
So if anyone else had this problem, just double check your entire ignition system.....
Posted: Wed May 30, 2012 5:56 pm
by PACMAN.AU
Went through my ignition system, I changed plugs, leads and still had the problem.
Found that the carbon button on the inside of the dizzy cap had broken. I am surprised the car ran at all. Problem solved though.
