Page 2 of 2
Re: S300 V2 Digital input
Posted: Sat May 24, 2014 7:06 am
by crixzc
Thank You
Posted: Mon Jun 23, 2014 8:43 am
by RyanR
I'm running into the same problem with an LC-2 hooked up to the serial in. I'm running the serial out on the LC-2 to I- digital in on the s300 v3 and it's reading roughly half of what the gauge attached to the LC-2 displays. I tried hooking up the ground from the serial out and there was no change.
Posted: Sat Jun 28, 2014 5:08 am
by rondoval
Same here, as already mentioned last year on this forum...
LC-1 hooked up to S300 V2 (SManager v2.3.3). Readings from the digital input are half of what is shown by LogWorks or logged on analog input (i.e. AFR=14 gives a reading of 7 on the digital in).
Posted: Thu Jul 10, 2014 10:41 am
by crixzc
Hondata? How did your testing go?
Posted: Thu Jul 10, 2014 10:43 am
by crixzc
Hondata wrote:We can test it again, but we have not made any alterations in that area and I would expect it to work. It will take us a few weeks to be able to test this.
Posted: Fri Jul 18, 2014 8:13 am
We've made some changes to the LC1 digital input which should fix this. We think the LC1 digital steam was getting out of sync. It doesn't have a checksum for the digital packet, you you can't tell if the data is valid or not.
Posted: Thu Jul 24, 2014 9:38 pm
by RyanR
So will these changes be implemented in the next version of sManager?
Posted: Fri Jul 25, 2014 8:41 am
Yes. However, we don't have a release planned for a while.
