Page 2 of 3
Re: Honda Accord CL9 Euro 03-08 Model Flashpro works
Posted: Wed Mar 21, 2012 2:16 pm
by Zoro2006
peter.d wrote:So what exactly Hondata did to help you ?
Are you running FlashPro with TSX ECU ?
Hondata made new FlashPro manager where you can disable EVAP errors that CL9 euro dash would be clean from "check engine" light.
Core58 and I using TSX ECU 07-08 with FlashPro in our Accord CL9 euro. You must buy same kit as for TSX 04-06
Posted: Sun Mar 25, 2012 1:54 am
by viggen
hello for the accord cl9 do i need to buy this kit
http://www.hondata.com/flashpro_tsx.html
and the Adapter kit for the tsx 2004-2006 then a tsx ecu 07-08?
does it work on cl9's older than 2006?
thank you
Posted: Sun Mar 25, 2012 5:10 am
by Zoro2006
viggen wrote:hello for the accord cl9 do i need to buy this kit
thank you
yes
all works for 2003-2008 CL9
Posted: Wed Apr 25, 2012 8:24 am
by at933
Hi!
please once again explain me what I need to run FlashPro?
Do I have to send my ECU (37820-RBB-E06) somewhere?
Or I have to buy TSX ECU?
And how do I attach Flash Pro?
Posted: Wed Apr 25, 2012 9:03 am
by mabo
at933 wrote:Hi!
Only the last once again and only for you .
http://hondata.com/flashpro_tsx.html
1. You have to pick a 07-08 TSX ecu, flashpro cant flash any other CL9 ecu, just 07-08.
Everything else you can find here :
http://hondata.com/downloads/tsx_ecu_removal.pdf
http://hondata.com/downloads/04-06_flas ... nstall.pdf
http://www.youtube.com/watch?v=dHwkDRBJyp0 - with this video even a dumb can register and connect ecu.
Change your mind bro, if you cant find what is on top then i afraid youll need a compass soon to find a WC in your home.
Posted: Wed Apr 25, 2012 11:42 am
by at933
Posted: Thu Apr 26, 2012 2:26 am
by Zoro2006
at933 wrote:;)
Maybe you are Sirmais from LV ? :)
Posted: Thu Apr 26, 2012 11:47 pm
by at933
True. That's me.
Posted: Fri Apr 27, 2012 10:59 am
by Zoro2006
at933 wrote:True. That's me.
Meet in FastLap if you be there :) Explain all and even show if you want.
Posted: Thu Jun 14, 2012 7:54 am
by Mounty
Hi, so I have flashpro ordered. I was just checking my CAN Connector, and there seems to be no slot empty in which to connect the CAN Adapter harness. There are 7 slots, like in the pdf showing how it's done, but all are full!!?? Is there any other place where I could connect the CAN Adapter, or am i out of luck?? I saw there is a green Block, right beside a Brown Block, closer to the front of the glove box, with color dotted wires, but i fear this is my audio system connections.. I drive an 07 Accord cl9 executive. Any help would be very cool!!
Mounty
Posted: Sat Jun 16, 2012 12:48 am
by Mounty
So, i found out, thanks to mabo, that i will have to solder wires to the High and Low CAN connectors, either on the ecu/ecm side of the wiring harness, or up under the glove box to the CAN connector.. (Red/grey dots>CAN Low and White/grey dots>CAN High, 3rd plug from the top in the pictures) if anyone is having troubles @ ecu/ecm side. it's the right most connector, pinned as in picture below.
Mounty
Posted: Mon Jul 09, 2012 11:18 am
by K_A_N_O
i cant even find those green canbus plugs on my ukdm cl9 :/
Posted: Wed Sep 12, 2012 11:10 am
by dinoc
does the cruise control work?
Posted: Thu Sep 13, 2012 1:39 pm
by K_A_N_O
dinoc wrote:does the cruise control work?
havnt even checked mine tbh. ill check and let you know, pretty sure it does though
Posted: Thu Sep 13, 2012 2:18 pm
by dinoc
please do, sombody above reported it didn't work
