Page 2 of 3
Re: FD2 Asia 155hp Automatic Transmission (fault isolated)
Posted: Thu Sep 29, 2011 6:44 am
by IcEMoCHa
skier wrote:Hi,
I have managed to isolate the fault point. Seem like a bug.
If ur speed adjustment of the panel display is set to 0, the problem never appear. regardless of what gearing you put in the gear table.
the EPS sign only appear if the speed adjustment is set to another value other than 0 for automatic transmission of FD2 and after driving around.
This doesn't work. I tried setting both ECU and dash speed adjustment to 0% and still the speed signal becomes 0km/h at random times.
The dash speed adjustment doesn't seem to be working, I tried setting -13% and 0% doesn't seem to change the speed. But the ECU speed adjustment does show a difference.
The EPS indicator is caused by speed signal becomes 0km/h as described by the DTC screenshot shown on my post here :
http://www.hondata.com/forum/viewtopic.php?f=29&t=12177
Posted: Thu Sep 29, 2011 6:52 am
by IcEMoCHa
The 2 DTC that appear on HDS everytime I upload a calibration using flashpro showned here. Is it normal?
Hope Hondata can solve this problem soon. I'm willing to participate to get this EPS warning indicator problem fixed as soon as possible.
Posted: Thu Sep 29, 2011 6:59 pm
by IcEMoCHa
I've found a problem when I set both speed adjustment to 0%. Assuming correct speed adjustment is -13%.
It will sometimes show the correct speed as verified by GPS speed. And sometimes the wrong speed.
I was travelling at 90km/h constantly(correct speed on GPS), maintaining throttle to keep that speed it would suddenly jump to 97km/h(wrong speed according to GPS).
And when I was accelerating slowly from 70km/h(wrong speed on GPS), it would go 71,72,73 then suddenly showing 68km/h(correct speed based on GPS).
It doesn't happen when I set the speed adjustment to -13%. Hondata please look into this, it might be the one causing the EPS speed signal lost.
Thank you
Posted: Fri Sep 30, 2011 1:41 am
by IcEMoCHa
I can confirm that the above mentioned problem is related to the EPS indicator. Because after my speed jump from 98 to 107, the EPS warning indicator lighted up.
Posted: Mon Oct 03, 2011 8:23 am
by IcEMoCHa
Hello Hondata,
Using my feedbacks from above, is it possible to make a test fix calibration to find out the source of the speed signal loss?
I'm willing to cooperate with you on an effort to fix this problem.
Thank you.
Regards,
SH
Posted: Fri Oct 28, 2011 4:15 am
by IcEMoCHa
Question to Hondata, our cars are using 5-speed automatic transmission.
Is it ok to leave the 6th gear as 0? I noticed that the gear shown in the datalog is not correct as it keeps showing that I'm using 6th gear all the time during cruising which doesn't make sense because its only 5 speed. I cruise at 5th gear and occasionally downshift to 3 or 4 but it doesn't show up in datalog. Just showing 6th gear all the way.
Might this be causing the VSS to go 0km/h at times and EPS indicator light up?
Attached image below
Posted: Wed Dec 21, 2011 10:30 am
by jbfd2ar
Hi Guys,
Sorry for the very late reply. I have not checked this thread after i saw Spunkster's reply
This is not something we can test as we do not have any of these vehicles here.
Anyway, heres my reply to some of the Qs people asked me.
I'm from Malaysia.
FD2 155hp, gear ratio for auto and manual are different.
My car is auto, so my tuner used 2.666, 1.534, 1.021, 0.720, 0.524, Final Drive Ratio=4.437
This should be the gear ratio for FD2 manual, 1st = 2.651, 2nd = 1.516, 3rd = 1.081, 4th = 0.772, 5th = 0.566, 6th = 0, Final = 4.562
1 guy who got a FD 2.0 155hp Honda Manual took a picture of the gear ratio for auto and manual, they are different as what flashpro shows. So, I'm pretty sure that the 2.666..... is correct for my car.
Any answers to this Q ? I'm sure it would help many.
Posted: Thu Dec 22, 2011 2:29 am
by IcEMoCHa
jbfd2ar wrote:Hi Guys,
I'm from Malaysia.
I see.. I've seen many different set of gear ratios from different places but don't know which is the correct one.. What are your settings for the sensor ECU and Dash speed correction settings?
Also I've dropped you a PM regarding a favor.. Thanks
Photo of US version Civic service manual..
Posted: Tue Dec 27, 2011 10:37 pm
by jbfd2ar
I dont have a copy of the calibration. I also dont try uploading any map on to my car or try to tune myself. I'm just trying to find a solution here and get my tuner to try.
my set up is change the internal of head and fill it up with k20a2's head stuff. and k20a2's 11.0:1 piston, reusing my stock crank and con rod. A very budget Type S conversion. Together with Intake Header Exhaust, makes 189hp on the wheels.
Posted: Fri Mar 02, 2012 2:22 am
by IcEMoCHa
Can you fix the calibration to only 5 gears and also can you fix the speed sensor %? We can't get accurate speed reading without setting it at -13% isn't it supposed to read same as stock at 0%?
Posted: Sat Jun 09, 2012 10:56 am
by yungming
I do not have this problem, you can contact me to fix it
Posted: Mon Mar 04, 2013 9:13 am
by stjimmy
yungming wrote:I do not have this problem, you can contact me to fix it
How did you fix it?
Please upload method here..
or can you PM me?
Posted: Sat Nov 02, 2013 10:09 am
by goodspeed
Any updates
Posted: Sat Nov 16, 2013 7:32 pm
by goodspeed
Managed to solve the gear display problem by setting the 6th gear as the same as ur 5 th gear ratio.
Pls try it. Now I have proper display on fp for the 5th gear only
Posted: Wed Mar 11, 2015 1:27 pm
by Keeganwcm
@goodspeed I hope you're still using your hondata on your fd2. I'm in Malaysia too and I just picked up my hondata 2 days ago. Fd2 Asia 155hp AT.
My tuner didn't quite explain how all the settings work neither do I understand them. However I have a very irritating problem with loosing my power steering from time to time per drive. Is this issue related to gear ratios?
Thanks for your help or anyone who can help thanks
