Re: Boost Controller - Seems to want to work but super sensi
Posted: Mon Aug 22, 2011 1:24 pm
"as im told by them"
Yyeeea... I had the same spiel, though different vendor. I wonder if a different solenoid would clear it up, I just don't want to spend the money to end up in the same spot.
Any datalogs/calibration of the problem? How similar are they to mine? Mine would spike like crazy unless I went in a higher gear. Almost like there's an entire second where it decides to do nothing, even still, when it DOES do something it takes time to level out.
Where do you get your +12v from? Have you tried the vaccuum line directly to the wastegate to make sure there is no spike?
Also, can you at least get yours regulating boost a bit like mine? Or is it just not working at all?
