Page 2 of 7
Posted: Mon Apr 04, 2011 10:13 am
Change value display with lambda/percentage change etc: Done for next release.
Serial wideband interface: Yes, in a future release.
Posted: Mon Apr 04, 2011 12:36 pm
by hdragster
I can't download this, it says is contaminated with a trojan :[
Posted: Mon Apr 04, 2011 1:24 pm
What antivirus software are you using?
Posted: Mon Apr 04, 2011 8:51 pm
by FreshDA9
Hondata wrote:Change value display with lambda/percentage change etc: Done for next release.
Thank you. used this tonight loved the cell coloring after making a change. look forward to using the serial input and losing a few of these cables im running.
Posted: Tue Apr 05, 2011 6:00 am
by AREA876
I would love to see Boost Control (PWM) enable though output A17 (IAB) for a JDM ECU in a future release.
Posted: Tue Apr 05, 2011 12:59 pm
by markodude
can anyone else confirm if boost control does or does not work in this release?
Posted: Wed Apr 06, 2011 5:22 am
by AREA876
markodude wrote:can anyone else confirm if boost control does or does not work in this release?
Yes boost control works via output A11 on USDM ECU
Posted: Sat Apr 09, 2011 9:53 pm
by hdragster
Spunkster wrote:What antivirus software are you using?
ESET Smart Security 4
Posted: Mon Apr 11, 2011 11:20 am
Try disabling your antivirus softwae, if that does not work, then uninstall the antivirus software.
Posted: Sun Apr 17, 2011 10:34 am
by FreshDA9
thank you for adding the highlighting to the lambda/percentage change views. i will be testing this out this week.
Since you are releasing your coil on plug system does this mean a new stable release should be out shortly? Might there be any code work for serial widebands yet?
Posted: Thu Apr 21, 2011 5:57 am
by Johnny_9
FreshDA9 wrote:thank you for adding the highlighting to the lambda/percentage change views. i will be testing this out this week.
is that one wb per cylinder?
Re: SManager V1.5.1 beta
Posted: Sat Apr 23, 2011 9:34 pm
by FreshDA9
no just a code to use a serial wideband so no more d10 or d14 and fusing with offsets to get stuff to match. i spend alot of time doing this for some reason.
Posted: Mon Apr 25, 2011 12:46 pm
by Tsuchinoko
Something is wrong with this version. After i changed some cell values and save, the pressure rows changed to strange values like 0 and 28999 mbar when i open the calibration. I realise this after i upload a map to the ecu and the car didn't start.
I went to the production version 1.4.8 and problem was solved the rows didn't change anymore.
Please see what is going on because some features of this new version are really usefull to me.
PS: This only happend with the 1.5.1 version before when i had the 1.5.0 never had this issue.
Posted: Mon Apr 25, 2011 4:37 pm
Can you email the calibration to support@hondata.com? (preferably both the calibrations from 1.4.8 and 1.5.1)
Also, can you tell us about the sequence of events which caused this problem?
Finally, what decimal separator, thousands separator and list separator do you use in Windows?
Posted: Tue Apr 26, 2011 3:25 am
by Tsuchinoko
Sorry but i already erase the bad calibrations anyway i will install again the 1.5.1 and make the changes to give me the issue.
1- I update the 1.5.1 version
2- I changed some ignition cell values and save
3- Turn off the computer
4- On the day after i upload the calibration to the ecu and the car didn't start, i realise that the inlet pressure rows values was not right.
5 - I tried again save the changes and see what happen, still had the same issue
6 - I install the 1.4.8 version made the changes and upload everything perfect.
I don't understand the last question can you please help me, to be able to understand what you want?
