Page 2 of 3
Posted: Thu Apr 29, 2010 9:11 am
by civicRSA
Above zero strim it will show the + values. Below zero there is just a blank for the strim.
Posted: Thu Apr 29, 2010 10:03 am
by Pir8pete
[quote="Hondata"]Pir8pete: Shift+F1 or View->Normal
How did this get changed? I never touched anything just ran the install over the exsisting installed version. Is this a default setting in this .1 version?
Posted: Mon May 03, 2010 2:30 pm
civicRSA: Does not do it here. What regional settings do you use?
Posted: Mon May 03, 2010 8:23 pm
by civicRSA
Regional settings checked all reset. Still doing it.
Posted: Wed May 12, 2010 1:21 pm
With V1.1.5.3 we have added the gear ratios. These are used by cruise control to determine if the clutch is slipping, and will cancel the cruise control at a certain point.
Would someone with a Euro CTR try a MAP calibration and tell us if cruise control works in 6th gear? You'll need to change the ratios from the default.
Posted: Wed May 12, 2010 1:26 pm
by civicRSA
I'll get on it. Will report back.
Posted: Thu May 13, 2010 2:32 am
by civicRSA
Confirmed. Speed cruise in 6th gear works on Euro CTR using MAP calibrations.
Well done Hondata
Posted: Thu May 13, 2010 9:01 am
Thanks for checking this.
Posted: Thu May 13, 2010 1:44 pm
by Gernby
Will ignition retard by gear be available for S2000's anytime soon?
Posted: Thu May 13, 2010 11:30 pm
by civicRSA
I see the function to disable the second coolant temp sensor.
I thought that you could disable it by un-checking use second coolant temp sensor for fan control.
Does this have and influence on the wideband input here?
If disabling the ECT2 can you not use ECT2 to control the fan?
Posted: Fri May 14, 2010 7:53 am
Gernby: probably not.
civicRSA: It is for race cars.
Posted: Fri May 14, 2010 8:14 am
by Gernby
Hondata wrote:Gernby: probably not.
Is that due to a technical difficulty, or just due to priorities?
Posted: Fri May 14, 2010 10:33 am
by civicRSA
Hondata wrote:civicRSA: It is for race cars.
So when using ECT2 for a wideband input which do you disable?
ECT2 sensor or ECT2 fan control
Posted: Mon May 17, 2010 11:32 am
Gernby: I have not looked to see if it is possible for the S2000 yet, but at the moment it is not our highest priority.
civicRSA: Just disabling the ECT2 should be enough.
Posted: Mon Jun 07, 2010 10:43 am
by Gernby
Now that the "Return To Stock" function has been moved, how can it be uploaded to the Secondary Calibration on the FP? I always keep the RTS calibration there as a backup.
