SManager V1.4.5 beta
Mikey3000
My antivirus won't let me run the new SManager
Post by Mikey3000 »
I know a warning about this was displayed but what can I do to make it work? A window pops up everytime I try to open SManager that says: Cannot open, file is corrupt.
boostedcivicsir
Re: SManager V1.4.5 beta
Post by boostedcivicsir »
Hondata wrote:V1.4.5.0
• Sensor window enhancements (alternating row colors to aid visibility, on/off parameters show as indicators).
• Graph window enhancements (better time axis labeling, ensure sensor labels are always visible).
• Table window enhancements (2D graph allows drag selection, 2D graph selects rows and columns with Shift and Ctrl clicks)
• Fixed PSP input increasing idle speed when PSP input used for other purposes.
• Added datalog comments.
• Parameters window now scrolls.
• Changed file association to work with Windows Vista / 7 security.
• Allow capital I and D when editing notes.
• Fixed 'Idle Speed Moving' table not showing temperature values in Celsius.
• Added support for Windows Themes.
• Added option to show 4 bar tables.
• Added option for closed loop using wideband lambda input.
• Added closed loop short term trim rate of change.
• Added burnout rev limiter.
Download here
awesome....no more 11.2k burnouts!
Boostin
Post by Boostin »
I just noticed that the scroll wheel on the mouse doesn't work (parameters window)
Just a suggestion....
Thanks, the improvement are amazing!
.-''-...-'Boostin'-...-''-.
mrvf
Post by mrvf »
hi guys...i never try this version, im on the fly with v1.4.4.1, everything its ok with this version (no bugs)?
When i try to make the update one time say that its up to date, another time tell that have new version and when i click to update give an error update
Try again, and if you get an error just download it directly from the downloads section of the website.
mrvf
Post by mrvf »
Spunkster wrote:Try again, and if you get an error just download it directly from the downloads section of the website.
Thats what i do, download directly. thanks
hdragster
Post by hdragster »
It will be nice if closed loop with wideband can be target by target lambda table. Not only for one targed voltage.
Hondata wrote:• Allow capital I and D when editing notes.
And I and D not changed cells now. Only Ctrl-I and Ctrl-D....
If I change something in 2D by mouse than I can't undo this change.
I agree instead of doing this conversion everytime =\
y=ax^2+bx+c
AN1
volts = 0-10
5-20
AN2
Volts = 0-0v
5-5
mr.sky
Post by mr.sky »
Cool new features. Wideband closed loop very interesting will see if I can get better fuel economy
